Question about Sony MBX-49 ASSY Motherboard
No Startup and Run
On my PCG-FX-120 sony vaio, the power light and drive momentarily comes on and will do that as many times as the power button is pressed but that's all it does.
Prior to this it was on and running and just died and has not come on since.
Any suggestions is appreciated.
  • 135 Answers
I have the same problem, park it for about 3 months and then it will ridiculously boot right up!
I have just discovered the problem to be cooling fan related which will damage the RAM from excess heat, so be sure fan is running...
If you continue to fight it and then just see the green LED on (no light on screen-BLACK SCREEN), RAM already damaged!
Posted on Feb 16, 2009
  • 86 Answers
Probably the power supply, take it to a reliable laptop lab
Posted on May 05, 2008
Sony Vaio will not power on with hard drive connected
I'd say it's time to do a close inspection of the hard drive connector/adapter, especially if it has any components mounted on it. If you can't see a problem you can fix like a short between two terminals, and you can't get another one, get an external USB drive (preferably the largest flash memory stick you can obtain) and set it up as a Linux bootable volume and use that to run your computer. You will probably have to set the BIOS to boot from a USB volume first.
Jan 07, 2014 | Sony Vaio Pcg-R505Tek...
Speed up a Sony Vaio Laptop Model PCG-5B1L
Start by installing this program CCLEANER found here: http://www.filehippo.com/download_ccleaner/ Run the cleaner, registry delete the results. Go to TOOLS> STARTUP disable all programs you do not need to start at windows startup. Next, Install MALWAREBYTES found here: http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL scan , delete any results. NEXT, open IE9 in the top right corner of the page is a "gear" icon, left click>Manage add-ons, Toolbars and extentions, disable any TOOLBARS and the add-ons you do not need, move down to Search Providers, delete ones you do not use. Toolbars and extra search engines are killers on IE speed. Trim the weight to speed up you web broswer. The more that added to your broswer the slower it's go to be. Same with your laptop at startup.
Nov 09, 2012 | Sony Vaio Laptop Pcg-5b1l Intel Pentium M...
Sony vaio pcg-3c1m does not start
recharge your battery or run the laptop while being connected to the AC adapter power
Mar 14, 2010 | Computers & Internet
Vaio pcg-k17
WinXP needs to run a utility to partition the drive and activate it first. Try running https://docs.microsoft.com/en-us/windows-hardware/drivers/devtest/devcon
May 20, 2017 | Sony VAIO K17 (PCGK17) PC Notebook
I have a sony vaio pcg. it powers on and does nothing else. the 2 little cooling fans come on but the hard drive doesn't run and screen won't come on. can anyone help me out. thanks
Its possible that you already have a bad hard drive. It may have crashed. Your system will not boot without the hard drive running. The computer will keep on trying to look for the Hard drive that's probably why it looks like its doing nothing. Bring your machine to sony and have them fix it. If you know how to open up your Vaio, try to check the Hard drive connection and see it its loose, if its not loose. its time to replace the hard drive.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Sony VAIO PCG-K35 Notebook
My sony vaio model pcg-7y1l is not working. When
i had the same prob this morning there are 3 things you can try
1 memery
2 proccessor
3 hard drive
if not any of them
try the dvd drive
if not that then try exsternal monitor if dont show on that then motherboard is gone
Aug 14, 2009 | Sony VAIO VGN-AR230G Notebook
Won't stay on
IS THIS WITH BOTH AC CORD AND BATTERY
you probably need a power supply
before you run out and buy one start and press f8 then start in safemode see if the same thing happens
also make sure your AC adapter is connecting with internal connection the internal connection can become loose or bent from constant plugging and unplugging
Jan 22, 2009 | Sony VAIO PCG-K35 Notebook
Computers & Internet Logo
184 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
