Question about Fisher and Paykel Washing Machines
Grey marks not on sheets when put into Aquasmart washer but appear after cycle is finished. Ran the cleaning procedure that was suggested in owners manual and ran the sheets again but before I ran the cycle again, I cleaned all grey marks by hand before rerunning again, more grey marks appeared. Help
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Do you use the EFFICIENCY option on the cycles.If you do have you tried turning the EFFICIENCY option off?Please reply with additional information and I am sure I can help you.By the way what cycle and options are you using? Looking forward to your reply.
Posted on Aug 21, 2010
Washer leaves a large deposit of black material on sheets after washing
i think you model has a tub clean mode. i would try to do that. basically no clothes, no detergent, just fill the bleach dispenser and run the tub clean mode. press power and then hold in the tub clean button on the right for 3 secs. then press start.
Mar 23, 2015 | LG Wm2301hw Front Load Washer 4.2 Cu. Ft...
Fisher and paykel does Epsom salts work in the rinse water
Hi! Have you completed a "Clean Up" cycle? It should prompt you every 100 washes to do a clean up - it should be under the "Lifestyle" menu. When you do it, I suggest you use OXY soaker (1 whole Cup) instead of normal detergent and make sure it is all HOT water. It soaks for 4 hours, but is very good at cleaning the bowl and workings to stop brown marks on your clothes and towels
Oct 10, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aquasmart error 245
Have you removed the inner bowl and check under pump cover ,if so have youput the cover on around th correct way.Is the flapper inside housing of pump obstructed.
Feb 12, 2014 | Fisher and Paykel Aquasmart wl80t65c
Aquasmart 8Kg washer- spin cycle short
my problem is I did two wash and then I put two thin curtain in to wash and that is when I had this problem
Jul 07, 2013 | Fisher and Paykel Aquasmart wl80t65c
My Fisher and Paykel Aquasmart is leaving white marks on my clothes. I am using the correct washing liquid, so how can I fix this? I am sick of re-washing half of my clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
May 24, 2013 | Fisher and Paykel Aquasmart wl80t65c
Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Wepurchased a Whirlpool duet sport wash machine in Nov. 2008. The machine stops and turns off before the final finse cycle leaving the clothes very very wet and does not finish the complete cycle for...
remove the bottom panel.inside usually on the right side is a book called a tech.sheet used by the servie technician.it will tell you how to put the washer into test mode and run diagnostics
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
