Question about B.C. Rich Nt Warlock Electric Guitar
There is a lose wire in my warlock near my input jack and i don't know where it goes
  • B.C. Rich Master
  • 5,603 Answers
First thing see how it "dresses" and where it will reach. Use a manifying glass to look for the place it broke from.
Also look at this site for typical connections... find your configration an select from likely schematic(s):
http://www.guitarelectronics.com/c=i6oG31ZJ8oxSumglUkeemRP9L/category/wiring_resources_guitar_wiring_diagrams/
Posted on Aug 21, 2010
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
Need wiring schematic for it warlock
Maybe one of these is similar?
http://www.bcrich.com/learn_schematics.html
Apr 30, 2011 | B.C. Rich BC Rich Warlock Revenge Electric...
My warlock makes this horrible noise as i plug in the cord. I don' have ANY idea why. I've been messing around with it and still nothing has worked out. It makes the sound as if my amp is turned all the...
If the noise is a pop or click, that's normal. Any other sound could be caused by too long a cord, which will produce noise while on the floor.
If it's not the cord, then you most likely have something wrong with the wiring inside the guitar. Have a luthier (guitar builder and technician) look at it, and s/he should be able to fix the problem.
Hope that helps!
Nov 21, 2010 | B.C. Rich Nt Warlock Electric Guitar
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
My warlock does not work no sound thru the amp. Is there a fuse somewhere on the guitar?
Try looking for a battery pack in case you have active pickups. Otherwise I'd check the output jack first if your cable is good.
Jun 17, 2010 | B.C. Rich Nt Warlock Electric Guitar
Have a BC rick I think warlock. Need to rewire
Search this site for one that matches your resources of switches, pots and pickups to find a typical wiring diagram.
http://www.guitarelectronics.com/category/wiringresources/
Feb 09, 2010 | Music
Broken input jack wires, which wires go were on the jack
If it's a two wire jack, the tip contact is signal, the sleeve contact is common ground (or minus).
If there is a coaxial wire, the center wire is signal and goes to the tip contact, the braided shield is ground and goes to sleeve contact.
If there are two ordinary wires, you need to measure with an ohmmeter / continuity tester which one is connected to the common ground (minus) - that will be the sleeve and the other wire will be the tip.
regards
3rq8 (Triarcuate)
Sep 08, 2009 | Music
How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
-mike
Mar 30, 2009 | B.C. Rich Nt Warlock Electric Guitar
B.C. Rich Nt Warlock Electric Guitar Logo
205 people viewed this question
Top B.C. Rich Music Experts
Eric
L. Sawyer
rhodesworks
Are you a B.C. Rich Music Expert? Answer questions, earn points and help others
