Question about Toro Lawn Mower With Toro Power Tools
Craftsman Eager 1 carburetor diagram. Does not look like a Briggs or Tecumseh carburetor. Can it be a Kohler. Will run for a couple of seconds when I spray gas into the air passage. How do I clean the carburetor?
3 Suggested Answers
  • 430 Answers
SOURCE: Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Posted on Jan 02, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Toro model 20007 recycler with a 6.5HP Tecumseh engine
This almost sounds like a pinhole in the primer bulb but I need to know if you did the following. Did you remove the jet and venturi tube in the bottom of the carb. and clean the BRASS orifice hole and BRASS tube holes? If you did not then It will act just like the symptoms you described. Also check to see if your float bowl nut has holes in the side of it. IF it does then make sure the hole(s) are clean. Also make sure the fuel selector is all the way ON. Adittionally if the carb to block mating gasket is torn or not secure it will also perform as you stated.
Lastly the open the fuel air mixture screw on the side of the carb about 1/8th turn and see if the performance changes.
If the problem persists ....
This is dangerous due to the risk of fire but....
If you have any carb cleaner you can give it a quick shot in the nmating areas just after you start it before it gets hot to see if it speeds up. If it does, you have a vacuum leak. It is better to use an unlit propane torch if you have one.
Thanks for using FixYa,
Kelly
P.s. If the problem does persist I will need your complete engine number to proceed in troubleshooting.
Posted on May 21, 2010
Testimonial: "Thanks for the info. I ordered a rebuild kit for the carburetor so i can replace the gaskets. And i ordered a new primer bulb. The engine is a Tecumseh LV195EA-362003B 6.5 hp engine on a Toro model 20007 recycler mower. Do I need to remove the welch plugs?"
Craftsman 6.0 eager-1 self propelled lawnmower starts then stalla after 3 seconds
there is a fuel problem somewhere. more likely the carburetor bowl has water or debris in it. clean it real good.
Apr 30, 2017 | Craftsman Garden
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
I recently bought a Craftsman GT 5000 model number 917-276011. The serial number is 081503B002444. What year was this tractor made? I would appreciate any input.
Usually the quickest way to date lawn tractors is to look for the date code (Briggs and Stratton) or the D.O.M. (Tecumseh) for example. So on a Briggs engine there is a long three part series of numbers: model; type; and code. The code is the date code and the first two digits are the last two digits of the year made, the next two are the two digit month, followed by the next two which are the two digits for the day. This is how I get a decent idea of the age of a mower, assuming the original engine is on the machine of course. If you have a Tecumseh engine, it has a four digit DOM before 2004 and a five digit from 2004 on. The first digit of the four digit version is the last digit of the year. From 2004 on with the five digit the first two digits represent the last two digits of the year. Either way with Tecumseh engines the last three digits would be the day of the year. For example a Tecumseh engine 05222 would have been made on August 10, 2005. If you have a Kohler, I am not sure about that one as I have not had to date one yet, but the vast majority of the engines I deal with for Craftsman, including my own are Briggs and Stratton.
I hope you find this helpful.
Aug 10, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
I mixed up one spring and the mower idles low on craftsman eager-1 5.0 22 inch cut
I think that model may use the Tecumseh engine and carburetor application. Here is a diagram of what your machine (carb/choke and governor) should look like.
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
May 14, 2011 | Craftsman Garden
I don't know what oil type to use for a Tecumseh 8.0 hp engine
Tecumseh recommended straight 30 weight (30w) for summer use. You can use 10w30 also.
5w30 for winter use.
Use a heavy duty oil because air cooled engines run hotter than you car engine. A brand like Briggs&Stratton, Craftsman, Kohler.
I have used full synthetic like Mobil One with great success also.
If you have any other questions, please ask!
Jan 10, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Toro Lawn Mower With Toro Power Tools Logo
1,403 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
