Question about Toshiba 24AF46 24" TV
"one for all " remote code for Toshiba model - 24AF46
Need Remote Controler Codes for Toshiba Remote for Toshiba Model TP61H60 a 1998 Big Scrren
Your Toshiba remote should have the necessary codes to control your Toshiba TV unless one is much older than the other.
If your RCA remote is programmable, you can use its "code search" feature to find an applicable code or codes. If a complete search of all codes stored in your RCA remote fails to find a code, you may have to try another programmable remote or simply wait until the replacement Toshiba remote arrives.
Sep 25, 2014 | Televison & Video
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
How can I remove the SAP on my television , model#24AF46 ?
Go to the Audio Setup menu - toggle to MTS and change SAP to Stereo
Oct 22, 2009 | Toshiba Televison & Video
Code for Magnavox Univ remote
Try one of these codes:
018, 021, 023, 071, 085, 090
If those don't work, respond with the model for the remote and we'll try some others. Also, if remote requires 4 digit codes, just put a 0 in front of each of the above.
Apr 06, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Uneiversal Remote Code
The model of the TV is not important as the code list is by Make only and usually list 3 ot 6 codes to try for each make. Having the Remote control model number is more important so you can find the right instructions and code for your remote.
Check here
http://www.jascoproducts.com/support/universal-remote-codes.asp
Feb 18, 2009 | Toshiba MW20H63 TV
Universal remote control codes for toshiba t.v. amd syphonic vcr
have a jensen universal remote need codes for toshiba tv vcr combo lost book.
Jan 19, 2009 | Directed 434MHZ Remote Control
Need the tv coes for my toshiba tv
I have a older Toshiba TV CE20F10,but I lost the codes tomy TV,Ineed them.Tkank you
Dec 12, 2008 | Toshiba CT-90157 Remote Control
Toshiba 24AF46 24" TV Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
