Question about Mitsubishi VS-50604 50" Rear Projection Television
I have a Mitsubishi VS-50604. The sound is working but the screen is blue. No picture. What is the problem?
  • 1,476 Answers
Andychen993,
Depending on how you have your unit hooked up you may have a switch in the wrong position or not have a signal to the TV. Blue screen is the option if no video signal is present. Is your audio going through an amplifier? If so check all the signal feeds to verify that you have a signal going to the TV.
The easiest way to check this would be to hook a DVD up directly to the TV using a separate audio and video cable. If you still have a blue screen I would go into the menus and see if the settings are correct for blue screen.
If everything checks out ok then you probably have a bad small signal board and will need to replace it.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which could be helpful to troubleshoot your unit. It explains how to troubleshoot a dead TV but the procedure is the same to isolate a defective board.
Thanks for using FixYa and for the generous rating. We supply these answers for free.
hardrocko
Posted on Aug 21, 2010
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
I have a Mitsubishi vs-50604 and I was watching the TV and there was a popping noise, the TV went out. There was the familiar smell of burned electronics and now the green light flashes in sync with a...
Hello:
This may be due to failure of the power supply or related circuits,the burning may of been a capacitor or capacitors that may of exploded, changing these will return the set to normal.
Oct 05, 2011 | Mitsubishi VS-50604 50" Rear Projection...
Have a blue screen and sound, and when i click my input buttons i only have ant-A and ant-B no inputs 1-2-3 or dvd
I would call Mitsubishi if you have the original remote the set may have (most do) a hard reset that will restore all inputs.
It consists of a 4 digit code by model number, I have a list of the codes somewhere(I am on the road today) and with the set on you enter the numbers and the set turns off and comes back on reset.
SD TECH
Apr 14, 2011 | Mitsubishi VS-50604 50" Rear Projection...
I have a 50" projection screen tv model #
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Power knockout, TV screen is only blue with sound.
It Knocked out your turners, Call Encompass Parts 1-800-638-3328
Dec 31, 2009 | Mitsubishi VS-50604 50" Rear Projection...
Sound is O.K. no picture?
mitsubishi vs4561c projection tv no picture screen is blue sound is ok
Dec 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
50604 tv is trying to program channels how do i stop it ?
have a look here for your replacement mitsubishi remote:
http://www.electronicadventure.us/mitsubishi.htm
regards
Nov 26, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
