Question about HP Office Equipment & Supplies
My hp 309 printer is feeding the paper slightly crooked, thus printing is slight off.
5 Suggested Answers
cariandco
  • 39 Answers
SOURCE: Contents alignment on printed/copied paper
I would recommend a good cleaning of the rollers with a damp rag (old t-shirts are great for this). Some canned air to blow out the insides always seems to improve operation.
If this is helpful to you, would you please rate this solution? Thanks!
Posted on Jul 18, 2008
SOURCE: Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
Posted on May 12, 2009
  • 905 Answers
SOURCE: paper feeds improperly
Check the rollers at the back of the paper tray. You likely will find one that has a coating of "paper dust" that prevents it from grabbing pages as well as the other roller does, causing pages to be skewed. Clean off the roller with an old toothbrush, but don't use alcohol as it tends to dry out the rubber component.
Posted on Jun 11, 2010
  • 225 Answers
SOURCE: my canon pixma MP210, is not feeding the paper
There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
Disconnect the cables and rotate the printer in a way it stands on its back.
Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
Posted on Aug 01, 2010
Hp deskjet 3512 feeds paper in crooked
Hello, Vicki -
I found a HP discussion board where someone posted the same question, but for a different model HP printer. See all the replies here:
https://h30434.www3.hp.com/t5/Inkjet-Printing/Paper-feeding-in-crooked/td-p/6334779
Best wishes.
Jan 15, 2018 | HP Office Equipment & Supplies
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
When trying to print a document, the paper goes in crooked. Then my printer says there's no paper. Of course, there is plenty of paper and it's straight before headed to the printer.
If it goes in crooked, there could be a slight paper jam. Take the top off or open it up anyways and check the feed roller to make sure it is not sticky or jammed.
Nov 10, 2010 | Office Equipment & Supplies
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
Jan 07, 2010 | HP Photosmart C7280 Printer
Epson R340 does not feed paper or feeds it crooked so print is not square. Out of paper error when paper does not feed.
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Jan 02, 2010 | Epson Stylus Photo R340 InkJet Printer
Paper feeds crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Alignment page is printing crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 06, 2009 | HP PSC 750xi All-In-One InkJet Printer
HP Deskjet 6540 Alignment
Yeah, the only thing that can cause this is paper feed problems.
There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
Jul 03, 2008 | HP DeskJet 6540 InkJet Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
