Question about Cameras
On my powerShot SD 800 IS-Lens won't extend and retract properly-Seems to stick-Then camera screen gives me the message "lens error" Restart camera" which does not fix the problem..The last four or five pictures I took immediately before this started were very blurry..Please advise!!
    Sergeant:
    Champion:
  • 298 Answers
Try starting the camera in > playback or picture view mode,and then go into photo mode extend and retract the lens (zoom) return to
picture viewing mode and press the power button to turn the cam
off.In the future use the > button to start the camera this works for
Nikon cameras( ps Its a good idea to brush or blow the dust out of
the lens area also as preventive maintenance.)
The blurring may be related to ISO Speed
If the lens is fully retracting and closing then brushing or blowing
out the lens area may remedy the problem of seemingly sticking
Posted on May 03, 2008
    President:
  • 2,712 Answers
Hello astric6138,
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty
, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If your issue is not resolved, please do not assign
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved (remember that at times a bit of
    to and fro dialogue may be necessary to resolve an issue).
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated.
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
    IrishDruid
    Genius:
  • 3,422 Answers
Do the following to fix the lens problem:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Now turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. Take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. A lot of people have reported success with this method. HOWEVER, there is some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables.
Fix #7: Try forcing the lens. Many people have also reported success with this method. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include pulling, pushing, rotating or twisting on the lens barrel while hitting the power button. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the lens barrel side that has the largest gap. While doing these, listen for a click that indicates that the lens barrel guide pins have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Goodluck,
Please don't forget to rate or accept the solution
    Guru:
  • 1,342 Answers
Click HERE for explanations and probable fixes
  • 405 Answers
Sounds like the lens motor is wearing out, or sometimes small pieces of debris like sand can get stuck in the lens assembly and jam it. I would contact the manufacturer or store you purchased it from to determine your warranty status on the camera before trying to service it yourself.
If it is out of warranty you take a small flat screwdriver and slowly pry on the lens assembly while powering it on to get it to extend so you can take pic's. However if the it the lens motor this will not work.
Good Luck
Hope this Helps!
    Genius:
  • 1,142 Answers
Please do a reset of the camera...take the batteires out...make sure no extrenal power is connected to the camera. keep it off for around 20 minutes...then put in the batteries back in..turn on the camera and check if the problem reoccours..please let me know what happens..would tell you further steps if this does not help
  • 4,102 Answers
Hi take out the battery and any mem card thats in it then hit the camera into the palm of your other hand this will dislodge any grit or dirt that is down the side of the lense. If this still dont solve your problem then the lense motor needs replacing
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Unfortunately this is a well known problem, which affects many models of PowerShot cameras. Llease click http://www.e18error.com/ to find out more about this problem, with instructions included on how to attempt to repair the problem.
A summary of the steps are as follows:
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
Hope this helps.
Lens error
Try the procedures in this tip before taking the camera in for repairs.
Sep 12, 2012 | Canon PowerShot S95 Digital Camera
I turned my Cannon G9 camera on and 'lens error. restart camera' is the message I see. The lens will not retract and the camera does not function at all except for the message and the opening...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 31, 2011 | Canon PowerShot G9 Digital Camera
Lens barrel is stuck in the out position on my Canon Powershot SD1100 IS. Error message reads: "Lens error, restart camera". To my knowledge the camera has not been dropped and the barrel seems...
Jul 20, 2011 | Canon PowerShot SD1100 IS Digital Camera
My canon ixus 75 is not turning on properly the zoom lense is stuck out and wont retract. When i turn it on it says "lens error reset camera&quot
OK, assuming the batteries are ok, the problem is within the mechanism for the lens being too 'binding' while it operates.
Sometimes, people put their finger on the barrel of the lens when it retracts or extends.
If you reset the camera and it still does this, the camera needs to be serviced by Canon.
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd500?pageKeyCode=requestRepair
Jun 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Lens error
Same problem here - the forum posting on the SD 500 seems to be a bit more active (for the same problem).
http://www.fixya.com/support/t102982-e_18_problem
I have been trying to get some images or a service manual for the SD 700, with no luck...
Mar 15, 2008 | Canon PowerShot SD700 IS Digital ELPH /...
A460 lens error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 02, 2008 | Canon PowerShot A460 Digital Camera
Cameras Logo
103 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
