Question about GPX D2816 DVD Player
Door won't open - GPX D2816 DVD Player
    President:
  • 1,285 Answers
Unplug device for 5-10 min.......plug back up before dvd tries to reload press the stop/eject button
Posted on Aug 21, 2010
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Fuel door won't open
Fixed. In the glove box there is a vallet button. I pushed it and now my trunk and fuel door work. and what this has to do with my trunk and fuel door not functioning , I have no idea. Hope this helps someone else.
Apr 05, 2012 | 1998 Cadillac DeVille
Why wont the rear door open on my 2009 gmc acadia
from inside or outside ? if won't open from inside your child safety lock is probably tripped. if won't open from outside you probably have a lock rod that popped off inside the door, in which I would have the dealer fix it, it involves taking door pad off and when you can't open door to take pad off ,most of the time it damages it.
Mar 19, 2012 | 2009 GMC Acadia
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
1999 aurora front door won't open from outside with either remote or key won't open from inside with handle
If you can't open the door you can pull the corresponding seat to gain access and remove the inner door panel
Oct 29, 2011 | 1999 Oldsmobile Aurora
Garage door won't open
You probably have a broken spring on your door
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
GPX D2816 DVD Player Logo
132 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
