Question about Cobra 19 DX IV CB Radio
Recieving problems My unit apparently transmits OK, but I don't hear anything unless I'm very close to the sender. A radio check right beside another car will appear OK, but as soon as we pull of I can't hear a thing. Everyone says they can hear me just fine. One person told me that they had a similar problem with their unit and according to Cobra, who fixed it under warrenty, it was the speaker. Could a speaker do this? Any ideas?
  • 773 Answers
Turn the RF gain all the way up and leave it there. Also turn the squelch down until you hear white noise, then turn it up just until it goes away.
RF gain is how sensitive your receive is. The higher it is, the more range you have. There really is no need to turn it down ever, unless you are trying to not hear some one out in the distance. Normal operation, RF gain should be all the way up.
Now squelch is used to quiet non signal noise. Like white noise or interference noise, Or other radios with a really weak signal that you can't hear completely any way.
You just want it so it just quiets the fuzz noise. Depending on background interference and the amount of radio traffic, the may have to be adjusted to silence the noise you don't want to hear. When a strong audio signal is received, it will break the squelch, the higher the squelch is set, the stronger the signal needs to be to break it, otherwise it will silence it.
Posted on Oct 03, 2009
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
No sound on unit
There are any number of reasons for no sound. I will assume you're using new batteries or fully charged batteries. The simplest reason is that a wire has become disconnected from the speaker. This would make the radio sound the same on as off. To test this see if the radio has a way of turning the squelch off, sometimes a simple push button, sometimes a menu setting, sometimes a dial to adjust the squelch setting. If there is no hissing, sometime very loud so turn your volume down first, then either the audio output amp is dead or a wire to the speaker is broken or disconnected. I today's radios the audio amp is most likely a simple small IC but, it could be inside an all-in-one chip and if it's proprietary getting the chip could be a problem. If it's a simple audio chip you'll have to find a replacement or rig up another audio amp IC to work as a replacement. Let's hope for the simple broken or disconnected wire which should be easy enough to fix.
Now, if when you remove the squelch you hear the hissing but you still cannot hear transmitting from your other radio, it could be that the one transmitting is in fact NOT transmitting an not that the other radio cannot hear. You have checked that both radios can or can not hear someone else's radio right?
Assuming you do know that one radio cannot hear what the other can and make no sound other than hissing when the squelch is off the problem is either in the RF or IF sections of the radio's receiver. In general this used to be a more complex repair so let's go another easy fix by going to the very first place the RF comes in, the antenna.
Just like the audio section when a speaker wire is disconnected sometimes the wire or trace going to the bottom of the antenna can become disconnected or broken. To check this bring a good transmitting radio very close to the one that hisses but does not hear the transmitting radio and see if any place as close as you can get the two radios causes the non-hearing radio to hear the transmitting radio. If so, then look for a problem with the antenna connection.
If none of these easy things bring the problem to heel then there's probably something amiss in the RF or IF receiver sections. If the radio has one or two chips that do all the work here then see if you can get both and replace them. I haven't even taken apart my own small FRS radios to see how complex the receivers are in these so I won't go any further than that since I simply don't know your radio.
I hope that helps.
Apr 07, 2014 | Radio Communications
Motorola Talkabout MR will not transmit
From reading through your settings, they appear to be identical. Except, I am not certain what Vox 2 is, or B5 0. If the number 2 beside VOX is a setting, you should set it to off or zero. Otherwise, they appear like they should work. (VOX = voice activation, and when enabled will cause a radio to transmit when it hears a sound, voice, etc.)
If you are using an audio device such as an earpiece or headset, be certain you are plugging it in with the radio turned OFF.
Lack of transmit can also be a sign of a bad battery or bad battery connection. You might try swapping the batteries and see if the problem moves to the other radio.
If these are less than one year old, use the number in your user guide to contact Motorola for a possible warranty replacement.
Best regards.
May 18, 2013 | Motorola Talkabout T5700 AA (22 Channels)...
I can't get my ntl twr500 2 way radios to conect to each other
Do you hear anything on one unit when transmitting on the other?
If you do, it will show that the unit is transmitting.
One or both might be set on the wrong channel.
Check both units this way/ Check each to see if they are receiving any signal when the other transmits. Hope it helps.
Mar 26, 2013 | Cobra microTALK LI 7200-2 WX VP Two Way...
I can't hear people
Make sure you don't try to transmit without a proper CB antenna, it will damage & blow out the power transistors! If you have another CB close by, try listening without the antenna attached If you even faintly hear whats transmitted by the other CB, your antenna cable is probably shorted out... AGAIN don't try to transmit with no antenna or a shorted cable it will damage the unit!
Oct 22, 2010 | Cobra 29 LTD CB Radio
Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Nov 10, 2009 | Motorola Walkie Talkies 2-Way Radio
Uniden Oceanus not transmitting
You may have a sub-channel/privacy channel activated. Unless the person/s you are trying to talk to have the same channel and code set they will not be able to hear you. Check your manual for specific instructions on how to reset it to the default.
Jun 11, 2009 | Uniden Oceanus DSC Wham ready Fixed Mount...
Cant hear anyone
Is the squelch off? Is there even a crackle from the speaker? Does it appear to go into transmit?
If you have a friend can listen in while you try transmitting, get him to let you know if voice can be heard, or a carrier appears (on AM). If TX OK, try sideband, if OK, look for faulty speaker/ socket/ wiring. If no audio on TX, suspect the audio amp is bad.
May 15, 2008 | Cobra 19 DX 40-Channels Base CB Radio
Cobra 19 DX IV CB Radio Logo
310 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
