Question about Toshiba 62MX195 62" HDTV
Toshiba 62mx195 just hooked up to cable blue light blinks yellow light blinks and turns off with no picture
    Sergeant:
  • 252 Answers
This is an error code that means your TV's light bulb needs changing. You can buy light bulbs for your TV online or at your nearest TV retailer or TV repair shop. Cost is about $20.00 for a new bulb.
Posted on Aug 21, 2010
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
I bought a used Toshiba 62mx195 with what u was told was only a bad bulb... great, bought and replaced bulb, now overtime I turn it on I have one color variance... either everything is blue or been or...
Make sure every input does that too. If not, you probably have a bad hook up from the device or the T.V. If not, it's probably your color wheel or DMB board.
Jun 23, 2011 | Toshiba Televison & Video
The light is blinking and wont turn on
Can you tell me I turn the toshiba on and there is no picture but the blue and yellow light keeps blinking
Apr 28, 2011 | Toshiba 56HM195 56" Projection HDTV
Television turns on with yellow blinking light then blue light but no picture
check your cables, check all input sources. How old is the set?
Mar 18, 2010 | Toshiba 62MX195 62" HDTV
I have a toshiba 62mx195 with a bad light engine does anybody repair light engines?
Hello
Im having problems with my 62mx195.
The I have a good picture but i have shadows next to or on certain objects. It occurs over the whole screen at different scenes of show. There are blue shadows that pop up intermittently. I have tried hooking up different DVD players to the TV to see if there is a difference, but nothing. It seems minor but it annoying as hell. I hope it is not an Light Engine.
Nov 21, 2009 | Toshiba 62MX195 62" HDTV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
I recently moved my toshiba 62mx195 across country it was well wrapped in bubble wrap and moving blankets, Now we go to turn it on and nuthinghappens except the timer/rec blinks yellow then the power blue...
Your Tv power supply is in protection, this means it wont start up, could be static. Rather take this to a Service Centre to check, If you have insurance claim it under the section travel/moving goods etc
Dec 05, 2008 | Toshiba 62MX195 62" HDTV
Toshiba 62MX195 62" HDTV Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
