Question about Toshiba TDP-S8 Multimedia Projector
Does not detect input source
My Toshiba Data Projector TDP-S8, turns on fine and displays the toshiba
logo screen on the wall, it looks just great. However, when I plug in the RGB Cable to my toshiba laptop computer satellite R15 series, Nothing from my laptop displays onto the wall. Do I need to add additional cables such as video output, or is could it be something else ?
  • Anonymous May 04, 2008
    my projector power on fine with the solid blue light on the wall...but it will not display anything from the pc to the wall..
  • heinen Jun 03, 2008
    I have the same problem, I have a toshiba laptop and the TDP-S8 projector. but for some reason it says no siginal and i can't get it to change from video to the computer on the projector. Is another cable needed? and on the projector do i need to have it plugged into the monitor or computer in?
  • 563 Answers
Hi Figburg
Press the Fn ( function button ) and while holding it down , press the button in your F-row with the 1 or 2 screens on it.
Should do the trick.
Posted on May 06, 2008
My Toshiba TDP-S8 projector will not power up at all.
hi,
check the mains chord, also check the power in the wall socket to which the projector is connected. if all these ok then,may be its power supply side have some problem. its an smps power supply. just check its input fuse on the smps. if it fond faulty the do not replace it suddenly. check is there is any thing faulty on the smps board. because the fuse will blow off only if there is any problem in smps. check it first before inserting fuse.
ok
Dec 21, 2010 | Toshiba TDP-S8 Multimedia Projector
Cant remember password for my toshiba tdp s8
I had a projector toshiba TDP-S8 but it is used when i turned it on it required a password what can I do
thank you
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Laptop won't run the data projector
connect your laptop and projector simultiniously and swith on both at the same time projector will recognise automatically.
Jan 26, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Aug 14, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP S8
First make sure your signal cable is ok and well connected.
Next check the projector input settings in the menu, and confirm that you have the correct input selected.
Also make sure your Laptop display settings allow for an external monitor.
Baba Anji
Dec 30, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
208 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
