Question about Car Audio & Video
Ba falcon 6 stack in dash cd player will not load cds how do i get at the unit it seems part of the dash
The player is not part of the dash. you should notice that the trim on the sides of the centre console will pull off and the clock above the LCD screen will pull off. Onces these are removed you will notice that the centre part of the dash is held in by 5 bolts. remove these and remove the plastic plate above the alcove in front of the gear stick and the centre unit will pull out. There are also a bunch of wire that connect to the bottom of the CD player - I'm still trying to get them off myself but I think they will just pull off.
Posted on Sep 13, 2010
My Falcon seems to take a while to start and I have to press the accelerator as well or it will stall, whats the deal?
My 2004 BA Falcon won't start. Apparently it's low - Fixya
www.fixya.com/cars/t12343045-2004_ba_falcon_start_apparently_s_low
Apr 8, 2012 - Apparently it's low on - Ford 2005 Falcon 4.0 question. ... Ba engine generally is strong, common fault is ecu, if hard starting when cold, pour hot water on computer and it ... If the headlights do not dim or go out, then the battery is likely ok..... Automatic 2004 BA Falcon stalls while driving ... Open Questions:.
My xr6 won't start. Comes up saying immobilized. - Fixya
www.fixya.com/.../t12430461-xr6_start_comes_up_saying_immobilized
Feb 6, 2012 - My xr6 won't start. ... Question about 2005 Ford Falcon 4.0 ... you will get airbag errors popping up for a few weeks then after a while it .... in a while it willstart and run for about 20 seconds, then it dies and won't start. ... Open Questions: ...You may NOT copy or distribute the content that appears on this site ...
Ford falcon sometimes won't start - Ford - Automotive - Whirlpool ...
forums.whirlpool.net.au > Automotive > Ford
WhirlpoolOct 26, 2010 - I have a EF Falcon that has an intermittent problem with starting. ... It might take a minute or 5 minutes or persistent retrying. ... Normally if you wiggle the T-Bar around it will then start. ... motor with a rebuilt unit, I had a remove starter on myalarm, and would use the remote start while using my jack-handle to ... Worst Car You Ever Owned
Jun 1, 2012
LPG conversion problems with stalling - Ford
Jan 16, 2012
More results from forums.whirlpool.net.au
2006 Ford Explorer Engine Stalls While Idling: 24 Complaints
www.carcomplaints.com/Ford/Explorer/.../engine_stalls_while_idling.sht...
Jan 27, 2016 | 2005 Ford Falcon 4.0
I feel like a dummy buy it says 6 cd player in my new to me 2003 explorer eddie bouer edition. Where is the place to put the cd's?
Check the manual for the exact loading procedure; the unit in the dash holds all 6. I think you have to press a button on the player until the display indicates "LOAD" and then put the CDs in one at a time. If you are putting in less than 6, you have to press the button again so the display no langer reads "LOAD". The manual will give you an exact explanation but the radio unit itself is what holds the CDs.
Jun 26, 2011 | 2003 Ford Expedition
6-disc Cd changer Mechanical Error
I talked to a dealer, all they could tell me is they have to send it to honda to fix it... a good 250$ for software fix...plus dealer will charge 50$ for each time they take the player out and in...
Jul 27, 2009 | 2005 Honda Accord
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
My ford falcon au cd player won't play cd's yet the tuner works
I have ford ute au series 2 and the cd tuner works but it wont excet cds? After pressing load and placing the cd in the driver it spits it out can any one help me with this?
Aug 11, 2008 | Audio Players & Recorders
Chm -s620 cd changer not loading cds
I've got the same problem with my Alpine changer. It seems like a widespread problem, but known cause or solutions.
Apr 03, 2008 | Alpine CHM-S620 6-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Car Audio & Video Logo
599 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
