Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
.I can turn the unit on but the screen is only
  • 11,361 Answers
You may have dying power supply that is not supplying full voltages to all the boards due to failed DC filter caps, that will be the first place to check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 21, 2010
How to clear Antitheft program activated message on the screen at ml350
There is an "Anti-theft protection active" message on my COMAND screen
When a COMAND unit is installed into a vehicle (whether during production or as a replacement) it is equipped with a PIN. This PIN will be associated to the VIN and relies on the communication network within the vehicle for validation. The network check from COMAND is performed at startup and if the internal vehicle network is not detected, "Anti-Theft protection active" will be displayed.
It is important to note that this message is NOT related to the vehicle's Anti-Theft alarm.
Either of the below procedures will temporarily remove the message and allow you to resume operation of the COMAND unit.
Please note that these are temporary solutions. We recommend visiting an authorized Mercedes-Benz dealership to have this situation permanently resolved.
· Press and hold down the COMAND power button for about ten seconds
Or
· Restart your vehicle
how to clear Antitheft program activated message on the screen on mercedes...
http://mercedes-benz.custhelp.com/app/answers/detail/a_id/76/~/there-is-an-anti-theft-protection-active-message-on-my-comand-screen
Dec 24, 2017 | Mercedes-Benz Cars & Trucks
Tom tom one wont turn on.the green charging light is on but still lit dimley when not charging
philip, try to charge with other adopter, it might be faulty
Apr 26, 2008 | GPS
MY ML 270 CDI COMAND DRAINS BATTERY
i think you will find the noise is the dvd player grinding away. if you have the remote trunk disconnect or at least take out te cart. the player in the mcs can be unplugged but requirs removing the mcs from the console tompull two plugs at the back.
Apr 22, 2012 | 2000 Mercedes-Benz M-Class
Why is my hp 900 keeps blinking but not printing?
i have the same printer and it sometimes responce same thing.
you give the print comand and then press printing button.
if again it shows the same thing then open it and check the piece of paper which stuck in it.
take out cartridge and place it again.
Dec 15, 2011 | HP 900 Inkjet Printer
Unpluged 37in sceptre tv and 15 min later pluged back in red on off lite no lit tv expert said leave un pluged 4o min then try did no responce is there a fuse? anyway no tv
Yes there are fuses, but if you have led lighting up then it's not the main fuse, Why was tv unplugged in the first place, did you have problems before with set? It sound like power supply is bad, and it would be cheaper to just replace, you can check with discount-merchants.com, or shopjimmy.com or even vancebaldwin.com
Dec 15, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Wont recover from sleep mode after depleted battery
plug out the batter and give the AC. turn it up. any light? if you dont have you have a problem with Mainboard that doesnt let the electircitiy goes in.
of course i am assuming your adapter is working :)
May 30, 2009 | Acer Computers & Internet
Unable to turn on receiver,marantz sr8002
First unplug unit...now check all consctions in the back of the unit and make sure none of the wires are touching together or touching any metal in back of unit! (speaker wires crossed is the main cause of thie) If this does not fix it it will have to be serviced by a pro!
Hope this does it for you!
Please rate my responce to your question.
Thank you!
Jan 07, 2009 | Audio Players & Recorders
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
89 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
