Question about Metz 45 CL-1 Flash
Contacts voltage can you tell me the across contact voltage ? My Fuji S9500 will only allow less than 400 volts
  • 30 Answers
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
Posted on Dec 08, 2008
    New Friend:
  • 21 Answers
My 45CL-1 measures 4.3V across the pc plug, which plugs into the camera's pc socket, or into a hot shoe adaptor. My 45CL-4 measures 9.4V. I've used both flashes successfully on my Canon 40D, which has a max trigger voltage into the hot shoe of about 30V, and max 250V into the pc socket on the side, which is stated in the Owner's Manual. The high trigger voltage was only on the 45CT-1, somewhere around 125V but I haven't measured a 45CT-1 myself. I'm sure that any of the 45CL series would be safe on any camera. Hope this helps. Neil
Posted on Jan 26, 2009
Use a digital volt meter:
Measures from center contact to outside contact of flash when flash is fully on.
atdlee@netzero.com
Posted on May 07, 2008
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
Memory card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 21, 2014 | Fujifilm FinePix S4400 Digital Camera,...
FUJIFILM FinePix JX500 digital camera says memory card protected
Nov 20, 2013 | Fujifilm FinePix JX500 14MP,5x Optical...
Screen says "Memory Card Protected" and will not take pictures.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2012 | Fujifilm FinePix C10 3x Optical Zoom, 10...
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Camera and flash gun trigger voltage
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Nov 27, 2008 | Cameras
What is the trigger voltage for Pentax AF 500FTZ
When using a digital camera with a flash unit of unknown trigger voltage, you are risking the life of your camera. Excessive trigger voltages can disable the cameras internal circuitry to the point where it is totally beyond repair.
I do not have, in my files. the trigger voltage for the specified flash unit. I only have the specs for larger portables and studio flash gear.
A simple test , however, will reveal the exact trigger voltage. If you have a multi-meter or a DV voltmeter with a 250 VDC range (just to be in the safe side) you can preform this test at home or an electronics service technician can do it for you in a few minutes.
The test lead are placed across the synch contacts on the foot of the unit or plugged into the sunch socket if the flash unit has one. If the reading is more that 4 or 5 volts you can still safely use the flash with the aid of a protector device which goes in between the flash and the camera. Theses are available at better camera shops and dealers.
Ed
Nov 16, 2008 | Pentax AF-500 FTZ TTL Flash
Vivitar trigger voltage
Yes, you can. The flash has a low-voltage trigger circuit.
Laszlo
Nov 14, 2008 | Cameras
Vivatar 283 and Nikon D70s
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Mar 10, 2008 | Vivitar 283 Flash
Metz 45 CL-1 Flash Logo
431 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
