Question about Kenmore 80412 Microwave Oven
Microwave KOT151S under counter model quit working right after installation. Power from house is funtioning, but the only thing working on microwave is the interior light. Is there a built-in fuse within the unit itself?? Any other ideas why its not working. also: new unit was in storage--new installation. thank you, Anne
  • Kenmore Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If some keys are still unresponsive, your membrane keypad has failed.
This can be due exposure to excessive heat, moisture or condensation, such as
due to storage in an unheated building.
It's usually economical to order a whole new controller here.
Let us know if we can help you further.
Posted on Aug 23, 2010
PLEASE HELP!!!!!! I had a house built 6 years ago and had an over the range microwave installed. The first one that came with the house was a GE. after like 6 months it would run for a few seconds and...
It may be that the exhaust duct is blocked or the filter is dirty.
That can cause the oven to run chronically hot, which damages the microwave.
The whole duct needs to be checked for any blockage.
You will need to remove the oven from the wall.
To remove it from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Oct 10, 2011 | Whirlpool MH2175XS Microwave Oven
I tried to turn my microwave on, it made a loud poping noice and now nothing on the microwave works.....no power....any suggestions??? I already checked the outside breaker box and it's fine. This is an...
Jhieb.. Are you in the Toronto Area.
It sound like you blew your power supply which are replacible.
There is a place in Mississauga Ont, Called Hitech link.
If you are that area, call them
Jul 20, 2010 | Amana ACO1860 Microwave Oven
Where do I find the fuse?
THE FUSE IS LOCATED UNDER THE HOUSING OF THE OVEN THERE SHOULD BE 4-6 SCREWS HOLDING THE TOP, LEFT AND RIGHT SIDES ON THE OVENTHEN SHOULD LIFT OFF IN ONE PIECE
BUT IF THE LIGHT IS STILL WORKING I DON'T THINK THE FUSE IS THE PROBLEM
Aug 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMB
there is a motor under the turn table that spins that tray.now some more expensive units would allow you to turn off the turn table if user wanted to,so check that out .but if not and its under warenty call a sears or any servicer that repairs you brand under warenty
Jan 25, 2009 | Magic Chef CMV1000B Microwave Oven
Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Cold air from outside coming in house through vent
Sounds like your damper (flap) outside is working, and that's probably the first thing to check. Wind may be also pulling the damper open from time to time. Hopefully the pipe fitting is sealed, and the pipe is insulated anywhere it runs through any unheated portion of the house. Some amount of cold air getting in will be unavoidable. The best bet next might be to look over the two pages in the installation instructions that deal with outside venting. If you don't have the installation instructions, you can get a copy here: http://www.geappliances.com/service_and_support/literature/ Then if you don't notice any obvious problems with the installation, it may be time to contact the installer for their two cents.
Feb 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 80412 Microwave Oven Logo
222 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
