Question about Intex 10' 30" Easy Set Pool Simple + Pump ()
How do ya order a magnetic spinner and rod I try to fix it and when I dispense water through the pump it stops and blows the breaker
  • 3 Answers
GOOD LUCK ! Intex # is 1-800-813-0206. M-F 8a - 9p, Sat. 8a - 1p. I've. Been trying myself for the same part, the phone rings, picks up, you get automatic prompting, then your on hold for eternity, til you get discussted, & hang up. Then when you try back, it's constantly busy conveiniantly till closing, then it starts all over again, without ever talking to anyone. Pool stores are only "allowed" to sell just the limited basics of parts. GOOD LUCK ! I'm going with aftermarket pump & filter. No more headaches, Just a pool my daughter can use
Posted on Jul 09, 2012
Keep blowing fuse for sterio which kills water pump and ac what are possible problems ?
FUSE WAREHOUSE HUH? oK, IF FUSE REPEATEDLY BLOWS, GLASS TUBE? CORRECT? tHEN YOU HAVE A SHORT CIRCUIT OR ACIRCUIT OVERLOA.D. tHE PUMP MAY BE TAKING OUT THE STEREO BECAUSEPUMPS PULL AMPS WAY MORE THAN PRETTY MUCH ANYRHING ELSE.. The pump should have a dedicated circuit. Or remove anything piggy backing on the pump circuit and bump the fuse 5 amps. Here is a trick of the trade. Go to autozone and chk out the AUTOMATIC CIRCUIT BREAKERS. bUY ONE THAT WILL FIT WHERE THE FUSE WENT.dO NOT GET THE SAME AMPERAGE. IT WILL FLUTTER LIKE A TURN SIGNAL FLASHER. NOT DESIRED BECAUSE WHILE THE BREAKER KEEPS ON AND OFFING, yOU WILL HAVE THE TIME TO REMOVE SUSPECTED WIRES. wHEN BREAKER STOPS TRIPPING, YOU HAVE FOUND THE PROBLEM CIRCUIT. tO SLOW DOW THE TRIPPING OF THE BREAKER, GET A HIGHER AMP BREAKER. bUT! dO NOT BUMP IT UP MORE THAN 5 AMPS AT A TIME OR THE RISK OF OVERHEATING YOUR WIRING SOARS. i ALWAYS HAD SOMEONE ASSIST AND WATCH FOR PROBLEMS LIKE WIRES HEATING UP, SMOKE OR SMELL. i DON'T MEAN TO SPOOK YOU, BUT YOU ARE BYPASSING THE DESIGNATED THRESHHOLD BY USING AN ALTERNATE TYPE OF CIRCUIT BREAKER WHICH RAISES THE THESHOLD IN ORDER TO DETECT AND LOCATE YOUR PROBLEM. iF THE
BREAKER CLICKS RAPIDLY, YOU HAVE A DEAD SHORTsLOW ORWIDELY SPACED TRIPPING MEANS YOU HAVE AN OVERLOAD SITUATION(TOO MUCH DEMAND ON THAT CIRCUIT. iF YOU WANT, AFTER ALL IS SAID AND DONE, TO USE AUTO CIRCUIT BREAKERS, gET THOSE OF THE SAME AMP RATING AS THE GLASS TUBE(BUSS FUSE. tO ME, THE METAL CASED ONES ARE FLAME PROOF WHERE PLASTIC MELTS .. tHEY AREN'T CHEAP BUT WORTH A TON OF BUSS FUSES. gOOD lUCK AND BE SAFE - T tHANKS FOR USING FIX-YAED NED-
Jul 24, 2014 | Keystone 2008 Cougar 289BHS
No water flow e90 fault code intex pure spa
Unplug the unit. The E90 code on the intex spa is due to a dirty water flow sensor. Remove the control panel and all the screw holding the casing on. In the white plastic piece on the discharge, top hose, you will see a silver nut with a black wire coming from it. That's the sensor. The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business!
Sep 27, 2013 | Intex 10x30" Metal Frame Pool w GFCI
AM 14 C commercial dishwasher. water leaks from "spinner spouts" when unit is not in use. Any ideas?
This sounds like the inlet magnetic solenoid valve is leaking, first thing to try is to turn off the main water valve beside the machine, if the water stops coming in then the inlet water solenoid valve or valves will need to be replaced
Good luck
Mar 26, 2011 | Hobart AM14C-155 Dishwasher
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
The fabric softener in my Maytag doesnt empty completely and a thick residue accumulates
Hello Donald,
I did not help out with much just wanted to make sure your machine type is a FAV6800A/FAV9800A. I will assume the machine type to be a FAV6800AWW. You may have gunk build up in the Fabric dispenser, I will attach some pics of opening mine, figured I would it clean up, it was a bit ugly. Place a 1” putty knife, mine is a 2.5” could not find my 1” at the location shown in the pic. Push in gently and lift up on that section of the Fabric dispenser top. Also refer to Page 33,34 of the Service Manual. Once removed check for gunk build up and clean out. I used a bleach and water solution and flushed the dispenser several times with water. If this doesn’t fix the issue we will have to verify water flow into the Fabric Dispenser. I do this by placing an external magnet on the left bumper to signal the control board the lid is closed and hold in very slightly the left lid latch on start of cycle to signal the control board the lid is locked. This is done in Service mode, I then turn on the Cold Water valve and the Fabric Dispenser solenoid in Service Mode to cause water flow into the dispenser and verify this action with the lid raised about an inch. This sound like a lot but it's a very easy process to master once ya give it a try. Maybe just a dispenser clean up will get ya going. Good luck and I hope this helps, Rich
Mar 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Bissell Proheat wont spray soap with uniformity
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhkl
Sep 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
BISSELL 1699 :WATER PUMPS THRU HOSE BUT NOT TO FLOOR NOZZLES
Did you blew thru the heater with both hoses off of it? If you did and it was clear, could be the pump, it is just working weakly. Is the top cover flush with the base in the back? If it has broken loose and has risen up, then it won't work. Here is a diagram that may help:
Aug 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Dvd rom
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
DVD wont close
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
Jan 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 dvd problem
bad dvd drive
try this
Jan 16, 2008 | Microsoft Xbox 360 Console
Intex 10' 30" Easy Set Pool Simple + Pump () Logo
55 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
