Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice maker problem with GE Profile refrigerator PSC23SGPA. Ice maker model No. WR30x10044 The diagnostic test result was OK when the unit did not have water. But after the water became ice, the rack would not rotate to remove the ice from the ice maker to the bucket. I heard about replacing the Thermistor (what is this?)is this the metal part below the ice maker that suppose to heat up to slightly melt the ice so it could be scoop out of the ice maker. Note: It did not seem to warm up or heat up after doing the diagnostic test. Is this replaceable or do I have to replace the whole unit. Would you recommend replacing the thermistor? if yes how?
  • 531 Answers
SOURCE: GE Profile Side-by-Side - Ice Maker Issue - Water Overflowing
your icemaker is bad
Posted on Apr 02, 2009
aasc
  • 1606 Answers
SOURCE: GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 16, 2009
aasc
  • 1606 Answers
SOURCE: P/N WR30X10044
The new P/N is WR30X10093 . It can be ordered from any parts house or online , for just over $ 100.00 .
Posted on Nov 29, 2009
  • 101 Answers
SOURCE: Bad thermistor easy to replace?
It is not "easy" but it is not rocket science either. You will have to have the unit pulled out from where it is installed to have access to the back of the unit to replace the thermsitor correctly (it feeds to the back through a hole in the upper right (as seen from the front) and follows the refrigerant tubing to the mechanical area where it connects to the control board on terminal #s 4 and 5. The thermistor itself is connected the the back of the evaporator plate. Depending on what year (and how accurate the assembly was) it should be on the right wing. Sometimes it was connected to the upper middle section of the evaporator plate like it is on the 6CAR. The repair can be done with common hand tools by someone who is average to above average handy. When you order the part, it should come with instructions.
There is short-cut for those units that are hard to remove from where they are installed but should only be used as a last resort since it requires cutting and splicing the thermsitor leads which if not done with care can lead to accelerated failure of the new thermsitor and/or control box.
Drop me a line if you need further assitance. - Subdriver
Posted on Mar 16, 2010
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Ice maker is not working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesnot work ge artic profile
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes and then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
You may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
P/N WR30X10044
Nov 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Jul 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Ice maker stoped working
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
235 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
