Question about HP Photosmart 3210 Printer
My printer is won't print either of the magenta colors, so all my pictures are coming out in this greenish yellow hue. I have done everything I can think of including cleaning the print heads, checking all color settings, trying to calibrate the color, etc etc and I can't get it to print those colors for the life of me even though there is still ink left in the cartridges....I'm afraid to waste money on new cartridges because I'm not even sure if that will fix the problem. Is anyone familiar with how to fix this problem?
  • HP Master
  • 1,830 Answers
Unfortunately, printers seem to have a short life to them.
We had to replace ours and buy new ink cartridges because
they make it to where you have to buy a different cartridge number for the same brand of printer.
How old is the printer? Base your decision on whether to replace it or not. If it is old, the best thing would be to replace it.
Posted on May 12, 2017
SOURCE: Magenta Cartridge
I have just found a solution on the hp support forum that says:-
Common problem of scanner optics dusted over requiring removing the laser/scanner, uncovering and cleaning mirrors and lenses. See the attached procedure. Takes about an hour, no parts.
On the second message on the following link you will see an attachment that has instructions for the above.
Posted on Aug 04, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 71 Answers
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Posted on Jun 20, 2009
  • 114 Answers
SOURCE: HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Posted on Mar 12, 2010
  • 3 Answers
SOURCE: No yellow ink. New cartridge recognized. HP Officejet Pro K5400
See here
Posted on Jul 25, 2010
When printing colour pictures they appear with greenish hue and there is no red at all...
For some reason it's not printing with the magenta ink. If you were out of that color it would tell you, so either all the magenta nozzles are clogged, or the printhead has gone bad.
At the top of the control panel is a button labeled Ink Management (or just Ink). Press that and choose Cleaning. Some machines will allow you to clean only certain colors - you want Magenta. When it's done, print a test page - also in the Ink Management menu. If it's improved, do it again until all the dots print for each color. Inkjet machines clean their nozzles by blasting them out with ink. If you're low on ink you should have spare cartridges ready to swap.
If no magenta prints at all, but the other colors are fine, your printhead has failed. If the machine is less than a year old it's a warranty repair, see Brother's website for the closest service center. If it's just past warranty, call Brother's customer service line and beg for a Work Order to be sent to a service center to cover your machine. Note that they will insist that your ink cartridges be genuine Brother brand before doing free repairs for ink problems.
If it's out of warranty, a repair would probably cost more than a new DCP 130C. Good luck.
Feb 15, 2011 | Brother DCP 130C All-In-One InkJet Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Copies print with a magenta hue. The color yellow doesn't print out. Tried 3 cartriages all the same. Clean printer also.
Try dabbing the cartridges on a paper towel, if you don't see a yellow line, the yellow is just empty, many have had the same complaint, new cartridges with no yellow inside.
Feb 01, 2010 | HP PSC 950 All-In-One InkJet Printer
When I print a picture it is greenish. All the
You need to make sure you are not using the photo magenta, your printer doesn't use photo magenta and it leaves the prints green. You need also to run the nozzle check print by holding the resume button until the green light flashes twice, and see if all colors are printed. If not you need a new printhead, the part number is on the side.
Nov 11, 2009 | Canon I960 InkJet Photo Printer
HP D7260 can't print color in black & white only - greenish hue
I am having the same problem, printing photos I took of the moon thru my telescope. Any solutions?
Jul 01, 2009 | HP Photosmart D7260 Printer
Everything's magenta!
Check in your printer driver settings "advanced" section, and see what the presets are. if the RGB or CYMK settings have a slider, see if the magenta is set at 100%. If it has a slider, try it at 90%, 80%, etc until you have a less pinkish hue. You can then create a printer profile which will work with the photo paper you are using.
Different photo papers can cause hues like this.
Also, you can remove pink any unpleasant hues with most photo image editors through color correction.
It's possible that you have a contaminated cartridge...especially if it's a refilled tri-color cartridge.
Dec 09, 2008 | Canon Office Equipment & Supplies
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Magenta Cartridge
Aug 03, 2008 | HP Color LaserJet 2600n Printer
Black does not print well
Try priting a test page to identify the color in questions.
Chances are you are running out of another color...
In reality the printers actually use other colors to print black, besides the black ink. (I.E. if its a picture etc...)
A greenish hue normally means your Magenta is running low.
Feb 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
56 people viewed this question
Ben Johnson
