Question about Danby Dehumidifiers
My ddr2510e is not draining? - Danby Dehumidifiers
  • Danby Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 29, 2010
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
Jul 28, 2012 | Danby Dehumidifiers
What size copper drain line do I need to run for a Zenith model ZD300 Dehumidifier. We can not use the bucket. Inspector of job wants a copper drain run for the Dehumidifiers.
That's got to be the dumbest thing I have heard today. This is a portable unit and is not equipped to have a copper line connected the the continuous drain. Only a 48' long garden hose is necessary to drain to a floor drain. Now, if you're trying to drain some other way. Keep in find that this model does not have a pump. It relies strictly on gravity to drain. In other words it will NOT drain UP.
Hope this helps and thanks for choosing FixYa.
Sep 19, 2011 | Whirlpool Dehumidifiers
How to set the dehumidityfier to drain through a hose than the bucket
As you're facing the rear of the unit, you will see a drain hose connection with a drain cap in place, don near floor level. Using a garden hose, no longer than 5 feet, remove the drain cap and save for future uses. Connect the garden hose section to the drain hose connection. Roll the dehumidifier to within 5 feet of a floor drain and place the hose at the inner edge of the floor drain. Be use the hose is sloped down and without bends or kinks. Plug the dehumidifier in, turn it ON and set the humidity extraction level at 35 - 40%. Monitor the hose to make sure its draining after 15 minutes of operation.
Keep in mind, the drain hose relies entirely on gravity to drain. It will not drain, if the hose is not sloped it's entire length down from the unit.
To assist you further, I have included a link to your Owner's Manual, that you can download and print for future reference. http://www.danby.com/cms/uploads/products/en_manual/DDR586R%20EFOM.pdf
I hope this helped you and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR586R Dehumidifier
I own a DDR2510E and I misplaced the manual, but I would sure greatly appreciate some help on what sort of settings to put it on in order to remove the HUMIDITY in my home. It is only a couple of months...
Try this when it loads click read more it should display it for you
http://www.needinstructions.com/consumer_electronics/instruction/3231_danby_ddr_dehumidifier_product_manual/
Jul 17, 2011 | Danby DDR451 Dehumidifier
Need manual for Danby millenium
Here is a link to your Owners Manual that you can download and print for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR2510E%2C_3010E%2C_4010E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 27, 2011 | Danby DDR401 Dehumidifier
I need the instruction booklet for this dehumidifier. Can you help? Denise
Denise, here's a link to the Owners Manual. You can download and print it, if you like.
May 05, 2011 | Danby DDR4010E Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Self drain is not working. I have to empty the
Assume you have a line to drain, line is probably clogged with sediment/lint from drain tray where it connects there. try blowing or backflushing the line at the drain end.
Dec 31, 2009 | Frigidaire Dehumidifiers
Do i need to disable the collection bucket to attach a drain line to my Matag dehumidifer M7DH45B2a? Or does it keep a full bucket and drain the overflow to the tubing drain?
No just connect the hose and open the hole to the unit to drain and return to usauge. it will fill to the drain opening and drain.
Aug 23, 2009 | Maytag M7DH45B2A Dehumidifier
I purchased a LG Dehumidifier MODEL LHD45EL and I followed instructions to attach a hose to it for the drain. I removed the drain hole cover and I don't see a drain hole connector or a hole to install it...
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Jul 22, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
181 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
