Question about Dryers
Maytag Neptune MDE5500AY Electric Dryer. Press timer, set time, close door, dryer switches to sensor reheat and drys the clothes. Cycle finished, dryer control pad stays lit and beeps intermitently. Dryer keeps switching to sensor reheat, 65 minutes. Replaced sensor bars, does tha same thing. Any ideas?? How do you access the error codes on the electronic push pad display??
  • Dryers Master
  • 8,220 Answers
Must be a stuck keypad is all I can think of.
Posted on Aug 21, 2010
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer shows "do" in time sensor area and does not run. What does this mean?
"DO" means DOOR OPEN and doesn't run because the safety feature on the dryer.
Be sure the door is correctly closed. If so, looks like the door switch is broken and needs to be replaced.
Good luck !
Sep 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MAytag dryer will not run. Has Power but will not start. No sensing light.
Was your dryer taking a long time to dry clothes? If so you should first check your vent and then suspect your dryer thermal cutoff.
Or,
this problem could be your door latch switch. Is your door more difficult to open, OR, sometimes pops open / or opens really easy? Then your door latch switch could be bad.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer wrinkles my clothes.
I only know of one or two things that might help.
One make sure there is not too many clothes in the dryer.
Two, if you have a setting for permanet press use this.
Good luck.
Jan 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
