Question about Kenmore 74602 Gas Dryer
When you push the start button, the dryer turns on, but shuts off when you let go of the button. Dryer does not stay on, When you continuously hold the button in the "on " position, the dryer operates and heats up.
  • 999 Answers
There is a switch on the motor that is active when the motor gets to speed. Either the switch is bad or the motor is not getting up to proper speed.
Eric
Posted on Aug 21, 2010
  • 27 Answers
Looks as faulty switch, depends on age can either clean contacts or just replace switch as the little catch on swich which holds in in on position may have snapped or sprained
Testimonial: "Thank you for your help. I'll try your suggestions. By the way, my dryer was purchased in '03 (model # 11073952101)-"
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
When I push the "push to start" button (knob) on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 14, 2011 | Kenmore Dryers
I have model #110.76712645 The dryer does not
open the door and push on the door switch paddle,if it doesn't click the door switch is broken.when you open the dryer door while it's running the dryer should shut off,if the switch breaks the dryer will either not run or will stay running,if the switch is clicking and is good then you have a broken push to start switch.this is the button you push on to start the dryer,this could break in the on position.let me know what you find
Jul 14, 2010 | Kenmore Dryers
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Dryer will not stay on after pushing start button
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Jan 30, 2009 | Kenmore 67082 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Kenmore 74602 Gas Dryer Logo
295 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
