Question about DEI Valet Keyless Entry System
I have what i believe is a viper system in my truck i just bought it has a valet remote i CANNOT GET UNLOCK FEATURE TO WORK BUT IT WILL UNLOCK WHAT CAN I DO TO MAKE IT UNLOCK ALSO
    New Friend:
  • 103 Answers
There is a green and blue wire on a white colored harness. You will need to verify that these wires are connected to the lock and unlock wires in the vehicle. This green and blue wires are on a 3 pin harness plugged into the alarm.
Posted on Aug 21, 2010
Where the **** is the Viper valet button?
Consider how the switch will be used before choosing a mounting location. Check for rear clearance before drilling a 9/32-inch hole and mounting the switch.The GRAY wire in the two-pin plug may also be used as a (+) ghost switch input and can be connected to any (+) switch in the vehicle. (See Feature Descriptions section of this guide.)
This is from the installation manual for the Viper 300. To answer your question, it is probably camoflaged. They only needed to tie +12vdc to the input line. What does this mean? Well, my best guess is, they are using one of your switches on your dash to act as the Valet function. Look for where the Gray wire, from the wiring harness of the Viper goes to: that WILL BE your hidden Valet switch. Best of luck!
Viper 300 ESP Installation Manual Plug in Harnesses Super Bright Led Valet...
Feb 15, 2016 | Remote Start System
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
I have a Viper 470v alarm and the keypad does everything it supposed to do as far as starting the truck locking and unlocking BUT it doesn't beep anymore and the screen doesn't reflect my status. It stays...
Is the red or blue light (LED)on the dash lit up solid? If it is then the alarm is in valet mode. 2 ways to take it out of valet. 1) open a door and press lock, unlock then lock again on your Viper remote. 2) turn the ignition on then off and press your valet/override button. The LED should go out and the beeps and status should come back. BTW you can also put the Viper into valet mode using the 2 methods above.
Feb 23, 2010 | Directed Electronics 479V Remote Gen 2...
Remote program
Open door
Key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Feb 18, 2010 | Viper Security and Remote Start System...
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Key out of IGN
Test unit
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
DEI Valet Keyless Entry System Logo
102 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
_-__-___-_
_-__-___-_
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
