Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
I dropped my calculator and now it says "ram cleared" whenever I turn it on. Is there any way I can fix it?
  • kakima Aug 21, 2010
    What happens when you press the CLEAR key?
    If that doesn't do it, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Does the calculator now turn on normally?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone over a month with no response to my query, I assume my suggested reset solved the problem.
Posted on Sep 24, 2010
Ram cleared, how to reset ram memory
If the calculator says RAM Cleared, then the RAM is cleared and there is no need for you to reset it. again.
If the calcularor says RAM Cleared everytime you turn calculator on, it may be due to a depleted backup battery.
Sep 07, 2011 | Texas Instruments TI-84 Plus Silver...
Screen says ram cleared
When the calculator is turned ON, power to refresh the RAM is supplied by the main batteries. However, when it is OFF, the RAM relies on the backup battery to keep itself refreshed.
If you get the RAM CLEARED message whenever you turn calculator ON, it most certainly is due to a depleted backup battery. You will have to replace the backup battery.
To avoid losing anything important from RAM (what do I say, you are already losing the contents of the RAM), make sure that main batteries are still good, then replace the backup battery.
You can verify the state of the main batteries in a battery tester or by connecting the calculator to the computer with TI USB Silver cable and TI Connect software. If you run into problem such as calculator not recognized it is most probably due to weak batteries.
When you connect it to computer try updating the OS if OS version to 2.53 MP or a more recent one..
Aug 30, 2011 | Texas Instruments TI-84 Plus Calculator
Everytime I turn on my calculator I get a messsage that says "TI-84 Plus Silver Edition 2.43 RAM cleared" and my calculator freezes and won't do anything. Please help!
Welcome to Fixya. To be able to fix the issue please click on the link below. It provides the steps on how to clear the error message.
TI-84 Plus Silver Edition 2.43 RAM cleared Fix
If you hve questions please let me know. Thanks for using Fixya.
Apr 08, 2011 | Texas Instruments TI-84 Plus Silver...
My calculator periodically will simply die. When
When you connect it to computer try updating the OS if OS version is not 1.19.
Mar 02, 2010 | Texas Instruments TI-83 Plus Calculator
The screen on my TI-83 Plus says, "RAM cleared" and won't do anything. It has the curser after I press "ON", but won't do anything else. I tried holding clear, holding ON, hitting it, etc. Can anyone...
Mar 02, 2010 | Texas Instruments TI-84 Plus Silver...
Whenever I try to graph the y= I get an Err: Invalid DIM 1: Quit message
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Feb 21, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
RAM CLEARED?
The most likely reason is that the backup battery is drained. Change the backup battery. When you get the Ram Cleared message, just press [CLEAR] to erase the message and start using the calculator.
Hope it helps.
Oct 28, 2009 | Texas Instruments TI-84 Plus Calculator
Sceen keeps saying RAM cleared even when I didn't clear it.
There is a small round battery under a small rectangular cover just above the other triple A batteries. It has most likely gone flat. try replacing it, then see if it works properly.
May 12, 2009 | Texas Instruments TI-83 Plus Calculator
Button Problems
happened to me be4, except all my buttons didn' t work. I just did what people do in movies. throw it aroun, step on it, bang it against walls, desks , ect. Then my teacher took it away. The banging cleared all my ram. It was weird, but it started working.
I think the circuit board moved, and i hit it back into alignment.
May 19, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
75 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
