Question about Whirlpool GU2400XTP Built-in Dishwasher
It's a Kenmore 665, (made by Whirlpool). The door won't close. It hits on the latch at the top.
    Genius:
  • 1,075 Answers
This is not just a kenmore problem this is a common fault ,and there is a way to fix it providing the switch is not broke.1,switch all electric off.and make sure the power is off.get the blunt end of a small spoon/tip of screwdriver .take a look at the inside of switch you will see a fork type/y shape divice inside the switch gently push it ontil it clicks,well done ,try door you will find it will work ok.adrian,,,,,,,,,
Posted on Aug 21, 2010
Kenmore model 665 top of door has pulled away from dishwasher
So.... Get some Bear Contact Cement in there. Let it set for 10 minutes then press the pulled away surface back into place and it should start holding.
Mar 03, 2015 | Kenmore Dishwashers
Kenmore 665 dishwasher problems
Check the door latch and switches.
Aug 22, 2014 | Kenmore Dishwashers
Why won't the door latch?
Make sure the door is not hitting the sides of your cabinet. Also make sure it is not hitting the screws that hold the mounting tabs (located at the top of your dishwasher) to your counter-top. If that's okay, try removing the racks and see if the door will close then. If still no, then you might have a broken latch or bent or broken hinges.
Jul 05, 2014 | Kenmore 24 in. 15932 Built-in Dishwasher
Washing machine won't start
Check your door when it closes, it should hit a push-in button above that door latch, at times I have seen the door hinge bent down just some, causing the door not to strike that button dead on.
If thats fine, then its likely to be the door latch assembly or the CCU board bad.
Oct 14, 2012 | Kenmore Washing Machines
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Own a Kenmore 665 dishwasher. The clean light is flashing (7 times) and the machine won't run. Have pulled the control panel and checked the door latch switches and they appear fine. No obvious burned...
It sensed a problem in the heater circuit. try this sequence to reset the code. If it comes back again you will have to determine a cause.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Sep 13, 2009 | Kenmore Dishwashers
Kenmore dishwasher 665 15752 wont cycle right
Sound like door/latch is not providing a secure door close anymore. Push on the door when the lights flash and see if this stops the blinking and continues with wash cycle. If it does, there is either somehing interfering withe the door closing fully, or the door latch on the door or dishwasher side is worn/defective.
Feb 22, 2009 | Kenmore Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
First time use, not working
The door switch is not closed or the board is not sensing the door is closed.
Push in at the top of the door to make sure it is latched at the top.
This is a common problem on the HE4's that was not a problem with the HE3's. We are hearing from Kenmore and Whirlpool that a fix is coming, a different latch I think.
Even if pushing in at the top makes it work, call for service so the problem can be addressed.
Post back if you have any questions.
Nov 12, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool GU2400XTP Built-in Dishwasher Logo
119 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
