Question about Whirlpool Duet GHW9150P Front Load Washer
F 21 showing on timer - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump is being obstructed by debris or some other foreign object as opposed to being faulty, although that can`t be ruled out...yet.
Here`s how to check it and clean it...
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removeable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removeable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to varify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the drain hose, hose from pump to tub for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you will likely require pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
macmarkus :)
Posted on Aug 21, 2010
Wiring timer switches
11-21-12
Copy following links to identify timer and wiring:
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM
http://waterheatertimer.org/Boxtype.html
Add a comment and describe which timer, and what load is controlled by that timer.
Oct 20, 2012 | General Electric Mechanical Timer, 120...
How do I change the time
Best place to start is the manual:
http://waterheatertimer.org/pdf/Raindrip-R673CT.pdf
The manual shows Technical assistance 888-825-4716
Are you wanting to change current time? If not, then read manual, and then add a comment with detailed question and where you are in the steps.
To set current time, or change current time, Press TIME button.
Hour digits will flash.
Use the triangle buttons to scroll up or down and select current hour.
Timer uses 24 hour clock so 11pm is hour 23/ and 9pm is hour 21/ and 1 pm is hour 13.
Press SET to enter hour.
Minute digits will start flashing. Use triangle buttons to select. Then press SET.
Days will start flashing. Use triangle buttons to select. Then press SET.
Sep 23, 2011 | Raindrip R673CT Digital Water Timer
Broken spring
You posted under WH21 Intermatic timer.
Intermatic does not show parts for that timer except 156EB1945A tripper.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Jul 17, 2011 | Electric Intermatic Wh 21 Water Heater...
The spring that turns off the power in my Intermatic WH21 timer is broken. Where can I buy a new spring?
Parts are not available for WH21 240V water heater timer.
Timer has 1 year limited warranty.
http://www.intermatic.com/customer%20service/frequently%20asked%20questions.aspx
WH21 is rated for 25Amps and works on water heaters up to 4500Watts.
Look at label on side of tank to see wattage.
WH21 is SPST and turns off one hot wire to water heater.
I ran a business for many years.
Cost of stocking, organizing, and shipping parts is near same cost as new timer.
Following page shows selection of replacement timers:
For example, I have tested WH40 and T104 and other timers that show on page.
Trippers and motors are available for Intermatic box timers WH40 and T104, so you can maintain these specific models for many years.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
WH40 and T104 timers are SPDT and turn off both hot wires to water heater.
Both timers will work on any wattage residential water heater
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
Feb 18, 2011 | Electric Intermatic Wh 21 Water Heater...
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
How do I set up the timer for the water heater?
My friend came over and did it for me. It was easy once he showed me how. Thanks anyway.
Sep 05, 2009 | Electric Intermatic Wh 21 Water Heater...
Timer stops turning when it turns off the power to the heater.
Possible cause....Electrical power to Timer is turned "OFF" by the Timer
Jun 12, 2009 | Electric Intermatic Wh 21 Water Heater...
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
