Question about HP Pavilion dv6000z Notebook
Have a hp pavilion dv6000. it turns on and the icons appear but will not connect to the internet, or open anything up. i do not have a disk either. the internet isnt a problem already called my isp and know its my pc....what to do?
    Sergeant:
    Champion:
  • 452 Answers
Power on your computer and press F8 to boot to Safe Mode. If that works then do a system restore while in Safe Mode.
Posted on Sep 03, 2010
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
No souds
is the mute button above the keyboard pressed? Are you running windows 7? Does the soundcard show up in your device manager? Also, on windows 7, the volume mixer provides separate channels for applications, rather than devices as in xp. Click the volume icon, open mixer, and check to see if the internet and other applications are muted. I use a DV6000 and this caused me trouble since this computer had a bad GPU that I fixed, which causes the ssound to stop working when it goes bad. The computer ended up being fine, I had simply forgot about the mixer.
If that doesn't work, try re-installing the sound drivers. If that doesn't work, you might have a faulty BGA (nvidia) chip, which will have to be reflown.
Mar 29, 2010 | HP Pavilion dv6000z Notebook
Nternet connection
Hi:
You need to go to :
www.hp.com
click on the drivers and support link,
type in the model of your laptop, and then download all the drivers they list.
Burn them to a disk, or copy to a thumb drive.
Transfer them to your HP, and open and install them, and you should be good to go!
Nov 23, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Wireless internet
your pc will not recognise your wireless,bloothtooth,or sd until you install the software and drivers for them.you can install all the drivers you need at the hp.com site .it just takes a while to navigate to ur model.down load wlan driver and software,dont need to restart system will detect install and detect available networks .
Feb 07, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000
video driver maby what about redoing windows formatt it all
Jan 18, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv6000z Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
