Question about Frigidaire Affinity ATF7000E Front Load Washer
I have A Frigidaire Model # LTF7000ESO The washer will not start. The washer makes a grinding noise. It sounds like the water valve will not open to let the water in the tub.
    Champion:
  • 245 Answers
It definately could be your inlet valve, There is a clean out underneath the front panel, thee screws underneath will release the bottom panel. There should be a coke can size cylinder with a screw off top. Remove that a check to see if there is any obstruction. Good luck!
Posted on Aug 21, 2010
Cycle stops at 12 minutes remaining in all cycles. Sounds like a grinding noise in unit. Then machine stops with Water remaining in drum. No blocks in pump. I run spin only to empty water. E11 code
Thanks for your post, Daniel!
Based off the information you have provided the cycles inside of your Frigidaire washer will stop at 12 minutes and making a grinding noise. I also see that you receive an E11 error code and that stands for a long fill time. I would recommend checking over the hoses to assure they are installed properly and not restricted. You may have an issue with your drain pump, motor, or water valve. I would recommend performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. I hope this information is helpful to you. -Matt
Dec 22, 2015 | Frigidaire ATF8000FS Affinity 3.5 Cu. Ft....
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Hi there! I have a Frigidaire Gallery GLGH1642FS1 stacked washer/dryer. Its making an awful grinding noise while trying to pump water out...the drum still seems to be turning though...any suggestions? Do I...
The washer is separate from the dryer as far as the systems go. It may be possible that you accidentally unplugged the connectors to the water hot valve when doing your repair.
The pump is probably the problem with the noise you describe. if the washer has a belt under the washer it is common for these pump bushings to go bad and make a grinding sound. There could be something stuck in the pump also.
Jun 25, 2014 | Washing Machines
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Maytag atlantis washer making loud grinding noise
The belt are tear and slap to the near obtacle need to replace /
The water magnetic valve are leaking ned to replace /the coil open or valve rusted.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Noise
Eileen, If the screeching is only happening on the fill and not during agitation or spin, I think we are safe to rule out the belt, pulley and bearing. Remove the fill hoses from the back of the washer and check to see if you have sand or gunk caught in the screens of the valve itself. If they are clear sounds like the water passing through the valve is making the noise. Another thing to check is the water pressure in the house. It should be around 55 psi., 75 psi max. I have seen it as high as 120psi with a bad regulator. This will cause noise and all kinds of problems. The part number for the fill valve is 131389300, according to the model posted....Catriver...post back.
Aug 27, 2006 | Frigidaire FWS833A Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
284 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
