Question about Aiwa NSX-TR77 CD Shelf System
Vol problem hiya the problem i have is that everytime i try and turn up the vol on this system i get a click sound and the system shuts off any help plz
    Brigadier General:
  • 8,546 Answers
Here is the entire troubleshooting section from the manual.
Your problem is presumed to be a shorted speaker wire. I assume you're not getting the failure ONLY at extremely high volume levels.
Care and maintenance
Occasional care and maintenance of the unit and the software
are needed to optimize the performance of your unit.
To clean the cabinet
Use a soft and dry cloth. If the unit surfaces are extremely
dirty, use a soft cloth lightly moistened with mild detergent
solution. Do not use strong solvents such as alcohol, benzine
or thinner.
To clean the tape heads
Dirty tape heads cause sound deterioration. After every 10
hours of use, clean the tape heads with a head cleaning
cassette. Refer to the instructions of the cleaning cassette.
To demagnetize the tape heads
Use a demagnetizing cassette after every 20 to 30 hours of
use. Refer to the instructions of the demagnetizing cassette.
Care of CDs
When a CD becomes dirty, wipe it from the center out with a
cleaning cloth. After playing a CD, store it in its case. Do
not keep it in hot or humid places.
Care of tapes
Store tapes in their cases after use. Do not leave tapes near
magnets, motors, television sets, or any source of
magnetism. Do not expose tapes to direct sunlight, or leave
them in a car parked in direct sunlight.
REFERENCE
Troubleshooting
If your unit fails to perform properly, check the following guide
and the relevant sections of the Operating Instructions.
There is no sound.
•Are the speakers and AC power cord connected properly?
The unit shut off suddenly.
•Possibly a short circuit in the speaker terminals.
Disconnect the AC power cord from the AC power outlet
and re-connect the speaker cords correctly.
The unit blacks out when the unit is turned off.
•Is ECO mode set to on?
Erroneous display.
•Reset the unit.
Poor radio reception.
•Check antenna connection. Adjust the antenna to find the
best reception.
•Move unit and antenna away from other electric appliances
and cords.
The tape does not run.
•Is the deck in pause?
Poor tape sound.
•Check for dirty heads. Clean them if needed.
•Use type I (normal) tapes.
Cannot record.
•Is the erasure prevention tab of the tape broken off? If so,
cover the detection slot with adhesive tape.
The CD player works poorly.
•Is the disc correctly loaded?
•Is the disc dirty?
•Is the lens affected by condensation? If so, wait
approximately one hour and try again.
Resetting the unit
If an unusual condition occurs in the display window or the
cassette deck, reset the unit as follows:
1 Press POWER to turn off the power.
If the power cannot be turned off, disconnect the AC power
cord, then plug it in again.
2 Hold down s and press POWER.
Everything stored in memory after purchase is cleared.
Posted on Apr 05, 2009
Tablet wont turn off
check your tab connector it may be damaged or out of place or loose, if loose it make contact with casing ,thinking is being used by an otg...hope this helps...then just follow trouble shhooting guides, holding down vol then power hold for at least 30 to 45 seconds then release power and then vol, wait about 2 mins before tab completly shuts down ...youll no longer hear the sound of a tab trying to keep running....times are approximate..if it doest help keep on reading ..eventually you'll find a few suggestions that may work together....
Dec 09, 2013 | Tablets & eReaders
Turns on, then shuts off, then turns on, then shuts off and so on
The internal board is gone. You need to get it replaced, although may be cheaper to buy new PA Speakers.
Jul 30, 2013 | Mackie SRM350V2 POWERED SPEAKER
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Sony HCD DX150: when we put the volume up past 29 the system shuts down and we have to unplug then plug in again to restart it.
Hello: You have a bad speaker on the system. Try disconnecting one speaker one at a time while turning the vol past 29. Until you discover when it stays on pass this point. Example you know it shuts down after 29, so start with the front right speaker disconnect it and turn vol pass 29 to see it it cuts off is so then the bad speaker is still connected to system, do this for all speakers until it does'nt turn off, when it does turn off you have removed the bad one. This is just to make sure its a speaker causing shut down, and not the amplifier it self...
Dec 06, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Everytime I turn the power on the tv stays on a few seconds & then shuts down
pull out the plug and whilst pressing the Vol-up and Ch-up buttons at the sametime, plug the AC cord into a wall socket,the set will stay on,test your voltages and monitor problems especially vertical. Or download my 27C-240 schematic,it will help you alot,request it at computec40@hotmail.com
Nov 04, 2009 | Sharp 32C-240 32" TV
Looking how to get a more distorted sound but cant find it. any recommendations
If you have 2 "volume controls" such as "vol" and "master vol" or "vol" and "gain", try turning them in opposite directions about 1/8 turn at a time, checking the sound at each increment, then reverse both if no results.
Driving the input a bit harder by turning up your instrument will help some also.
If that does not do enough for you, try a nice distortion pedal like a Boss Overdrive (the yellow one).
Happy harmonics !
Jul 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
No vol
check your connections on you home theater to all speakers
May 05, 2009 | Audio Players & Recorders
Delays in the system
mine glitched like this, i would backup contacts (save PIM.VOL file onto storage card) and master reset the phone by hold the center key and the power, then follow onscreen instructions
Apr 14, 2009 | Motorola Mobility Q9c Car Charger /...
Kenwood stacker system stereo
your speaker output is shorting either at the output terminals or at the speaker input . check the cabling . it will solve the problem
Feb 22, 2008 | Kenwood HTB-205 System
Aiwa NSX-TR77 CD Shelf System Logo
153 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
