Question about Whirlpool 8572546 Duet Sport Stacking Kit
Hi i have a whirlpool duet sport front load wash mechine that give me a code (Sd) it locks the mechine door it dosn't ring the clothes dry when this happens i would have to reset the circuit breaker for it to spin dry.what could this be.
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 30, 2010
Whirl pool duet sport the door is locked and it wont let me open it
You can remove the lower panel. Have to drain the hose - water rushes out...and then reach up insie the washer where the door latch is, there will be a ring that you can pull on that releases the lock.. Got that much done...but the beeping continues... Be sure to unplug the machine first!
Nov 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool front load washer will not open, even when the "done" light is lit. Any suggestions on how to get my clothes out?
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Brand NEW Whirlpool Duet Sport
After six failed attempts by your machine to lock the door F22 flashes.
Causes & Procedure:
Door lock mechanism is broken or removed from door.
Door switch or door unit failure.
1 Unplug / disconnect washer.
2 Check door switch lock unit.
3 Check wire harness connections to door switch/lock unit & the
Fault 22
Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28
The communication between the CCU & the MCU (motor control
unit cannot be sent correctly.
1 Unplug washer / Disconnect power
2 Check wire harness connection to the MCU, the motor & CCU
Check communication of the CCU board within the housing.
Make sure all grounding switches are engaged.
3 Check the drive system for any worn or failed components
4 Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
5 Verify CCU operation by running the Diagnostic Test or any
cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door lock
if you can open the top portion of the unit, reach down near the front lock of the unit and feel a ring at the bottom part and pull it down to manually open the door. i hope i solve your problem,
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 8572546 Duet Sport Stacking Kit Logo
287 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
