Question about DISH Network 322 DTV Receiver
I change the tv # 2 and now I can't get to set the signal
    Novelist:
    Champion:
  • DISH Network Expert
  • 286 Answers
Hey! My name is Becki Barned, and I am with Dish Network customer service! You have already gotten this issue resolved, but here are some steps in case you haven't! On tv2, try channel 60 and then 73. if that doesn't work, try to go to tv#1, press menu 6-1-5. Here, change (under tv2 out) the MODE setting from AIR (if it is on air) to CABLE, and vise versa. If the tv cannot go up past 69, make sure that the MODE is set to AIR. That's changing the setting for the TV#2, and with a new tv, this will usually fix it! Blog if any troubles!
Posted on Dec 25, 2010
I was using this TV for my Wii Console. Now when switching on TV says: NO SIGNAL! I do not have a remote and do not know to search for signal. I changed cable to HDMI1 and 2 but no change
How did you operate and set up the TV without the remote previously?
In any event you can purchase a universal remote from an electronics store. Pick one that is marked as working with your brand of TV.
As long as the TV is set in the correct mode for TV reception and has the correct tuner, and as long as you can use that remote to access the onscreen menu, you will be able to set up a channel search and get TV reception restored.
Before you do anything just check that the TV is in the correct mode for TV reception and not set instead as a monitor for connection to another device.
Dec 27, 2015 | Video Game Consoles & Games
Vizio tv says no signal
you should be able to do that with the remote by pushing "03"
or with manual buttons in menu under tuning selections , add channel 03
Apr 15, 2014 | Televison & Video
Ps2 no signal to tv
Make sure the Video Output settling is accurate to the TV/connection you are using (i.e. HDMI, analog etc)
This can be changed in the System Settings
If you have recently changed TV's - Set your PS3 back up on your previous TV and then go through the Video Output settings and change to the new TV your are using.
Hope this helps.
Jan 02, 2014 | Sony PlayStation 2 (PS2) Console
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
When i turn on my ps3 and change the tv output to the right one it says "no signal only audio" at first i thought it was my hdmi wire but i got a new one and tried that and it still doesn't...
Try the alternative connection, with other TV set. This means change your TV for moment and check it with the PS3. Use AV connection if you have provisions to make sure if your PS3 has video signal. This will ensure you that your PS3 is working fine. If you can't get any signal out, then check your PS3. Other options is, setting your TV's NTSC/PAL system to auto mode for video signal. This function can be done using remote control or user manual can also be a good help.
Apr 14, 2011 | Video Game Consoles & Games
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
DISH Network 322 DTV Receiver Logo
286 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
