Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Just spins around and around. It stays at the bottom and just spins in circles.
  • 640 Answers
Hose problems are common with these pool cleaners, and this is likely your problem. The hoses have been redesigned, but if you have a model older than this season, you are likely having hose problems. You can either replace the hose or attempt to straighten it. Lay the hose out in the grass (slightly stretched) and let it sit in the sun for several hours. It should help remold any kinks or bends. Do not store the hose for this cleaner in a coiled position, since that will make the problem worse.
Posted on May 25, 2011
  • dudy36 Aug 02, 2011
    I had this problem and did the following fix. I removed the cover and unscrewed the front piece which then allowed me to pull up the manifold. I took the end caps off the piston cylinders and lubricated the inside with water proof grease. Put it back together and it ran like new!
Electric clutch is staying stationery when engaged wires wrap around clutch and break off what is missing what keeps it from spinning around
Very hard to say without seeing it or a picture, but likely the stabilizer plate is broken from vibration.
May 08, 2016 | Garden
Corrosion frontloader kenmore
washer Corrosion Near bottom door and around the circle
Feb 19, 2014 | Kenmore HE2 Plus Front Load Washer
2002 Ford Explorer my steering wheel is super loose I can spin in around in a circle. I replaced the rack and pinion last year. Would the rack be causing this to happen?
No --the coupler at the bottom of the steering column
that attaches to the rack has come loose
Extremely dangerous & the first one I have ever heard of
Aug 31, 2013 | 2002 Dodge Neon
There is a yellow triangel with a circle around it... the car wont stay cranked unless you hit the gas
This is an anti-slip regulator control cutting in telling you have wheel slippage, and its in the process of stopping the wheel from spinning.
Keep us updated.
Nov 29, 2010 | 2000 Volkswagen Beetle
Blue circle around bottom menu buttons when pushed
haha, that is normal :) that happens when you press anything to show you what you have pressed :) and im sorry no, its how the phone was made.
Jun 28, 2009 | LG Vu CU920 Cellular Phone
Off balance spin/poor wringing
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have just instaled my harman kardon ks200 and there appears to be a problem? i can hear the cd spinning louder when listerning to track 1 than i can when listerning to track 10 eg. should there be a...
* Tech Stuff *
Audio CDs do not spin at a constant rate. They are designed to be read (for music) at a "constant linear velocity" of about 1.25 meters per second. The data is written in a tight spiral starting at the inside of the CD. The CD spins the fastest when reading the inside tracks and slows down as it reads towards the outside edge. Imagine circles on the CD surface. The inside ones would be smaller than the outside ones, of course. So, if you are reading evenly-spaced bits on the lines of those circles, you would need to read fewer outside circles per second than the small inside circles.
* Basic Issue *
When the player is reading Track 1 the CD is spinning at about 500 rpm. During the last tracks of a (full) CD it only needs to spin at about 200 rpm. It doesn't work the other way around for compatibility reasons.
* More Info *
This is why you are experiencing the difference in mechanical noise at different tracks. It doesn't necessarily reflect a defect, but understandably, a consumer would prefer a quieter system, which does differ between manufacturers and models (I couldn't specs for a KS200 HK device) Yet, if the noise is substantial, it may very well be indicative of a problem, e.g. something stuck in the drive and being whipped around in a circle at high speed. I wouldn't say this is particularly likely.
* Possible Help *
What would normally mitigate this issue is not getting too close to the player while listening. Normally having the primary listening position several few feet away (across the room) would suffice to minimize noise heard from fans and spooling CDs.
May 14, 2008 | Televison & Video
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
904 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
