Question about Technics SA-DX1050 Receiver
Mi problema es con un amplificador de sonido technics, modelo sa-dx1050. el problema es que cuando lo enciendo presenta en el display un mensaje "Overload" sobrecarga ya lo probe sin los parlantes y me sigue dando la falla. gracias!
Kimi
  • 277 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Posted on Nov 22, 2005
SOURCE: technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Posted on Aug 05, 2008
SOURCE: I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Posted on Jan 17, 2009
SOURCE: Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Posted on Jul 13, 2009
SOURCE: amplificador panasonic modelo sa-he7, se pone en error f70
rafatecnico amigo mio el error esta en la placa de coneccion de dispositivos auxiliares por favor revisa soldaduras de los dos transistores de potencia que se encuentran juntos y de los dos transistores de acople de los de potencia, si se encuentran bien entonces alguno de ellos esta averiado en cortocircuito o abierto
Posted on Aug 04, 2010
Hola, mi camara no dispara correctamente, al presionar el disparador se traba y aparece un rotulo en la pantalla que dice presione nuevamente y luego termina la foto, las fotos son de buena calidad... pero...
Cuando esto sucede en mi Nikon D-90, recibo un mensaje "ERR" en el panel de control. Nunca he conseguido un mensaje "vuelva a intentarlo". Sin embargo, suponiendo que esto es el mismo fallo, el manual del usuario dice que esto es un fallo de c?mara que puede ser aclarado por liberaci?n del obturador. En mi D-90 s?lo puedo hacerlo girando la c?mara y otra vez. A veces, tengo que quitar y volver a colocar la bater?a. El manual dice que si este problema persiste, debe enviarla a un centro de servicio autorizado de Nikon. Si lo que he sugerido que el problema no soluciona, sugiero que contactas Nikon support en www.Nikon.com para ver lo que proponen.
Dec 01, 2012 | Nikon D60 Digital Camera
Error de objetivo reiniciar camara
El origen de este error se encuentra en el mecanismo del zoom.
Existe una corona de reduccion o engranje de doble corona que hace la rotacion del mecanismo del zoom, que al forzarce se le desprenden unos dientes (plasticos) y comienza a patinar en el lugar Esto pasa también cuando se cruza el lente de zoom,cuando se rompe una o mas guias ,lo cual ocasiona que los sensores de foco y demas no logren su propia calibración y es ahí cuando la maquina te envia ese mensaje.
Similar problema se presenta en varias marcas y modelos, por lo que aqui puede obtener mayores detalles (con videos incluidos): Lens Error when turn camera
Suerte (recuerde calificar esta respuesta).
Jun 07, 2011 | Canon PowerShot A570 IS Digital Camera
Hola. No se si sirva el Circuito integrado de sonido de mi TV ya que no tiene sonido, pero conectandole un DVD en el auxiliar el sonido es perfecto. Tv broksonic modelo ctgv-4563tct ...
Hola, posiblemente el circuito integrado donde se realiza la seleccion de audio sea el problema y no el amplificador de audio ya que funciona con el DVD, habria que determinar cual IC realiza esta funcion tomando como referencia la salida demodulada de audio desde la etapa de frecuencia intermedia o adonde convergen todas las entradas de audio del TV.
Feb 26, 2011 | Broksonic Televison & Video
Tengo un amplificador de modelo jvc ax-1100bk que cuando lo enciendo me presenta una alerta de protector que problema puede ser por q no tengo el manual de reparacion
Casi por lo regular esa advertencia significa que el circuito amplificador de audio esta en cortocircuito y se necesita remplazarlo si eres tecnico tu lo puedes hacer si no llevalo a un taller de servicio
Jul 06, 2010 | JVC Audio Players & Recorders
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
Jun 09, 2010 | VeriFone VX510
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mi Equipo de sonido KENWOOD modelo UD-551M se apaga solo...
hola mi equipo kenwood ud551m tiene averiado micro funciones del amplificador donde lo puedo conseguir al componente gracias ana desde uruguay
Sep 19, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Technics SA-DX1050 Receiver Logo
238 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
