Question about Ovens
How concerned do we need to be about a small crack in the inside glass of a GE Profile Electric oven?
  • Ovens Master
  • 43,501 Answers
Very concerned..the heat will break it completely!!
Replace it immediately.
Range/Stove/ Oven Door Glass Replacement
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 21, 2010
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
THE GLASS ON MY OVEN DOOR IS STREAKED. CLEANER/CONDENSATION HAS GOTTEN UNDERNEATH GLASS. DRIVES ME CRAZY LOOKING STREAKED. ANY SUGGESTIONS? THANKS
usually there is some way to take either the handle off of the door, or take the door apart from the inside and you can seperate the parts of the door and remove the glass and clean it and replace everything back.
Jun 22, 2010 | GE Profile JTP18 Electric Single Oven
The inside glass of my built in double electric oven has cracked and now has a small piece of glass missing. Can the glass be ordered and replaced or do I need a repairman?
You should be able to obtain a replacement door glass from the manufacturer. They are normally available for most makes of ovens.
Jan 26, 2010 | Whirlpool Ovens
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Only one ring of the double ring element works
You have faulty regulator, or the element is faulty., not sure how you access the inside.
Hope this helps.
Dec 05, 2008 | GE Profile JTP18 Electric Single Oven
Replacing glass top on stove
I also have a ge spectra with a broken glass.
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
Oven bulb
i have a ge profile double oven and the glass cover on the top convection oven is held in place by grooves that latch onto the glass dome cover. Just turn the dome so that the handles on the glass dome cover are exposed. I used a flashlight and a screwdriver to push the dome to one side.
Dec 25, 2007 | GE Profile JTP56 Electric Double Oven
Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Dec 06, 2007 | GE Profile JT952 Electric Double Oven
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
172 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
