Compaq Presario F700. It keeps relooping without booting into Windows Vista (or even coming on). A hard reset + only AC power used to get it to come on but it wouldn't stay on. It would have a rolling or flickering screen and then freeze with a dark blue/black screen with no error messages. I would have to turn it off and on again. Before this it would have a flickering screen and then freeze with a blue screen and I would have to turn it off and on again. I think the problem is electrical but I haven't identified the source of the problem. Now when I do a hard reset + AC power only, it won't even come on. It just reloops without rebooting. What's the problem? How do I fix it? I don't have a backup, boot, or restore disk. There wasn't one with the computer when I bought it. In the future, how do I make one?! HELP!
    Problem Solver:
  • 12 Answers
It happens mostly when the boot file is missing hence you need to perform the recovery.
As it is a Compaq notebook it must have the D:/drive partition for the recovery manager which contain the image of your Windows.
You can try to access that by tapping F11 (or F10) while booting computer.
It will load the recovery manager and you can perform the recovery to reload the windows.it will give you the option to backup your personal data select that option and backup your data on Cd or external Hard drive.
This should resolve your issue.
Posted on Aug 21, 2010
Bios update for compaq presario f700 running linux mint
Nice OS. Dare I suggest boot into vista and install the firmware. Ensure there is no antivirus programme running as this may corrupt the BIOS!
Re boot into Mint.
Feb 17, 2013 | Compaq Presario F700 Series Laptop...
My compaq f700 laptop won't boot up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the compaq f700 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 30, 2013 | Compaq Presario F700 Series Laptop...
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Hi i have Compaq Pressario f700 with windows vista
if u have a Windows CD then u can try to restore ur system from that, use the repair option when the machine come on...ensure it boots from CD
u may have to change the boot seq in BIOS...
Jan 26, 2010 | Compaq Presario 700 470024-192 Notebook
Boot problems with compaq f700
Hello there
Hints:
1) You got a driver or device problem,
2) use the drivers that cam with your f700 particulary these ones, 1) video card 2) sound card (sometimes if driver is bad, it can cause these problems)
3) RAM problems, to isolate the problem, if you have the expertise take ount one ram module at a time and turn on the computer. see if these helps!
Apr 22, 2017 | Compaq Presario 700 470024-192 Notebook
Compaq f700
You have a hard drive probelem. This sounds like an intermitten actuator arm on teh disk spindle. What this means is that at boot up time the boot rom gives istructions to the operating system as to where to find the operation system. Apparently the actuator arm on the spindle that reads the hard drive is failing.
Oct 04, 2009 | Computers & Internet
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
if u want Drivers for Compaq presario F700 please use below link for win vista Os ..there is all drivers for u r laptop
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=3629568&lang=en
If this link is useful for u please rate me...........
Jun 14, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario powers on but dont boot
RE INSTALL YOUR OS (LINUX OR WINDOWS OR VISTA ETC)
Nov 24, 2007 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
