Can you tell me the age of a York condenser unit Model # E2FH030S06C Serial # EHFM292830 and York fan coil unit Model # F-RP036H06A Serial # EDFS114952 Thank you
  • 6 Answers
SOURCE: Goodman AWUF 3 ton fan coil unit
The evaporator is probably not excessively condensing in as much as the amount of condensate is directly proportional to the amount of humidity in the air. It sounds like the problem is more likely the primary drain is restricted by algae; if this is the case I suggest pouring a cup of bleach in the primary drain and see if that clears the primary drain. Note: the secondary is just that it is designed to keep the water from overflowing into the house. Hope this helps!
Posted on Oct 05, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
james3751
  • 614 Answers
SOURCE: How old and how many tons is my ac unit?
York is 5 ton
Posted on Jun 14, 2009
garing
  • 998 Answers
SOURCE: Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Posted on Aug 04, 2009
  • 232 Answers
SOURCE: BTU of an old Lennox condensing unit and A coil
38,000 btu AKA 3 ton
Posted on Sep 20, 2009
Testimonial: "Thank you for your help! Chong1238"
Zaiko e5 error how I can fix my ac
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in
heat mode. On cooling, the E5 will appear if the outside coil temp exceeds 68C. This is an indication
of condenser airflow reduced or non-existent. Using the procedure described above it is possible to
watch the condenser coil temp using the Temp down button and Medium fan speed combination to
display this temp. NB: if fans etc seem to be OK then measure thermistor resistance and refer to table
12. In case the problem is thermistor calibration.
Action: If unit is in cooling mode, examine both condenser fans are running. If
one is running then suspect a faulty motor. If both fans not running then
on units up to serial No. IBSA 01175, investigate the fan speed control
card located in enclosure on the LHS See fig 6.
If this checks OK then investigate main control card.
Fig 1, 2 or 3. Units with serial No's IBSA01176 and
onward are multi speed tapped wound motors not requiring a speed
control card. If both motors inoperative then suspect main control card
Aug 15, 2016 | Heating & Cooling
Where are the coils on a GE model GSS25LGPA CC fridge ... Are they under the fridge or in the back?
if u simply look at the unit u can tell either its a condenser fan cooled or evaporator coil cooled the back will have a wired coil like cage or at the bottom it will have a fan condenseor unit see pics attched
Apr 24, 2015 | GE Refrigerators
Hello! My Kenmore 53701300 dehumidifier comes on and will make noise that will tell you that it is working. The machine will make a noise and the coils in the back will almost immediately become cold,...
Dean, are you looking for someone to concur with your excellent evaluation of the problem? If so, I wholeheartedly concur. However, it may just be the automatic fan switch that is a vault and is replaceable. Fortunately, you have a house brand for Sears. And for the most part (depending on the age of the unit & which company really manufactured it for Sears) parts may still be available at
www.searspartscentral.com Armed with the model number you can search the site for that model unit and find an exploded view of all the parts. From there, you can price and order them, if you like.
In the meantime, consider the age of the unit, the cost of the part(s) and your time to research and then repair it, against buying a new one. If you do decide to scrap it, do it responsibly. As there is still Freon in the compressor.
I hope I was able to help you and thanks for choosing FixYa.
Aug 17, 2011 | Kenmore 53701 Dehumidifier
My ruud serial number 5427 M1496 07992 Model UAKA-024 Jaz Is not blowing cold air. I started the unit inside the house then went outside to see if the fan is working on the outside unit and it is...
1) Replace both fuses if there are any out by the unit
*also make sure the breakers are not tripped. there will be two
2) if you get the unit running inspect the outdoor coil under the outside fins to see if the coil is stopped up with dirt,grass, etc.
*if the coil is dirty, disconnect the unit from power, take the 4 screws out on the top of the unit that hold the fan motor assembly in place. Carefully set the entire motor, blade and assembly off to the side and be careful not to pull the motor wires loose. With a water hose and sprayer, carefully wash the condenser coil from the inside out. You will see a lot of debris on the outside fins you will have to wash off. Be careful not to have so much water pressure that you bend the aluminum fins on the coil itself.
** many times if the coil is stopped up this will cause the unit to overheat and trip breakers
Apr 13, 2011 | Ruud UAPA024 Air Conditioner
My ps 123sc is not cooling properly. it seems to be blowing some cool air but not enough to keep the freezer stuff frozen
Hello Drhoffs,
I understand that you are having a problem with you GE Refrigerator. The unit is blowing some cold air but not cold enough to keep items in the Freezer frozen. There are a few possible problems that can cause this situation:
1. Condensation coils are dirty
2. Fan not working (unplug unit)
3. Freezer coils are ice up (unplug unit)
4. Low on Freon (requires a service Tech and can be expensive)
Lets take this one step at a time thru the possible causes of the issue:
1. Condensations coils are dirty: You will need a vacuum with a crevice tool or air compressor or a long handle skinny brush>
a. Remove the kick plate on the bottom of the fridge
b. Use the above mentioned tools to remove all debris from underneath the fridge in the coils this can be accomplished from the front and back of the fridge
c. Once done reinstall the front kick plate
2. The Fan (if you can not hear the fan then follow these steps)
a. Remove all items from the Freezer
b. Remove the rear panel inside of the Freezer compartment
c. Locate the fan notice if the is turning if not remove and got to local hardware store and purchase a new one
d. Reinstall everything in reverse
3. Freezer coils
b. Remove the rear panel located in the back of the Freezer
c. Use a fan or heat source to speed the defrosting of the unit (it is also a good idea to put a cloth or something in the bottom of the Freezer to collect the water so that the Freezer pan does not over flow.)
d. Reinstall all items in reverse
4. Freon Level: This requires a licensed service technician and can be costly, weight the cost of the service call and repair to the cost of a new unit. If the cost to repair is more than half the price of a new unit purchase a new unit.
Thank you for choosing FixYa.com
Justin
Mar 28, 2011 | GE Profile Arctica Stainless Steel Top...
High head -suction 75 head 325. alredy cleaned evap coil and condenser
thats high head try cleaning the cond coil aging, and depending on the out door temp. was any thing changed the fan speed is right. or the unit is over charged.
Jul 17, 2010 | Goodman CLQ36AR49 Air Conditioner
YORK CONDENSING UNIT MODEL H1RA042506D WIRING SCUMATIC BLOWER MOTOR WILL NOT START WITH OUT A PUSH. START COMPASITOR MAY BE BAD BUT WITCH ONE IS IT. MOTOR NAME PLATE CALLS FOR A 370MFD. I FOUND A 36MFD...
The capacitor for the fan will read 370uf 5 uf. The 370 is voltage at cap. My guess would be a 7.5 uf cap for your fan. If you read the cap. it will tell you size. Fan caps go between 5 and 20 uf or microfards. Easy to replace you can do it yourself. Rus
Oct 29, 2009 | Heating & Cooling
Old unit blowing air, not cooled
You will have to contact the manufacture to get the age. The age can be determined through the serial number of that unit but often, only the manufacture can tell you. Window units are so inexpensive these days so I would recommend replacing it if you have done everything in regards to general maintenance of the unit like cleaning the indoor coil and rinsing out the coils at the back of the unit. Also, if you can get to the fan blades safely, they usually need a good cleaning as well. If you have done all this and it still doesn't cool, then I would replace it. I personally like the LG brand window units.
Mar 20, 2009 | Heating & Cooling
Air Conditioner Blows Warm Air (or at least not cool)
When serviced by a qualified service tech who finds and repairs a leak before recharging a system it is not illegal. However with the age of your unit you may want to balance the possible cost of a new unit against the cost of repairs to the old one. After repairs are made to an old unit you still have an old unit.
Jun 04, 2008 | Kenmore 72055 Air Conditioner
Heating & Cooling Logo
302 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
