Question about Broksonic TV
I have a one year old Broksonic 19" flat screen LCD TV. I wanted to use it as a computer monitor, so I hooked up the VGA cord and selected PC as the input. Nothing. What am I doing wrong? Charles Murfin Jacksonville, FL
  • Broksonic Master
  • 5,478 Answers
Is the computer set to send data to the video port? Laptops often have the external port disabled; check the BIOS. (This is often accessed by pressing F1, Esc or F2 before the OS loads. Check your documentation.) Then you can set the preferred monitor by looking at the Display settings.
Some desktops have a similar issue where only one port is active (DVI, HDMI, and VGA). You may need to connect a different monitor via the enabled port or use an adapter to get the VGA cable to mate with that port to change settings. (In the case of computers with video graphics cards and motherboard video ports, only one item is active. Try moving your cable with an adapter if needed to one of the other ports. Then change the BIOS setting if you do not want to continue using the adapter.)
Try a different video cable and make sure it is fully connected to both the computer and the monitor. Damaged cables are always suspect.
What OS are you using? Do you need to download drivers for the Broksonic? Go to www.broksonic.com and ask in the Product support section - they don't seem to have a direct link on the site. (For example some TVs are not compatible with the drivers in the Mac OS.)
I hope this helps.
Posted on Aug 21, 2010
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
Can I connect the LC19DV22U to my computer to use only as a monitor? And if so, how. I have misplaced the manual.
where did you hooked up the cable at the tv, what component input did you use like HDMI or VGA port? if your pc has the vga output you will use the vga port input of your tv then select in the source PC to get the signal from pc.
Oct 16, 2012 | Sharp LC19DV22U 19 in. LCD Television
Broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Apr 23, 2012 | Broksonic CCVG1935 19 in. LCD TV
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Hocking up my computer to a t.v.
Hook The VGA Cord (PC INPUT) into Your Laptop's Hookup Spot
Turn The TV Input to VGA Or PC or Computer and on the Laptop it should show up if you Hit The Function Key + F8
If You Are using A Desktop Hook It To the VGA Out Just Like You Where Hooking Up To A Computer and Turn The INPUT on the TV to VGA or PC or Computer and it should show up just like A Computer Monitor
Hope I Helped
Dec 20, 2008 | TruTech PM1919BXA1 19 in. LCD TV
VGA hookup to my Toshiba Satellite
Set the TV input to PC (that's ViewSonic's term for the VGA port).
Setting the computer to output to the PC may depend on your OS (XP, Vista). Reboot the computer after connecting the monitor and see if new hardware is found. Reboot again if you have a flickering screen. In Vista, right clicking on the desktop brings up various video and desktop options. Choose Screen Resolution and look for the multiple monitors line. Click Apply and OK after setting your desired output. In the Screen Resolution window you should see two monitor boxes (labeled 1 and 2) if the computer sees the monitor.
If the second monitor is not showing up (no new hardware found), check your BIOS and device drivers to see if you need to enable or update the drivers for the VGA port. Check your manual for the BIOS (often it is click F1 or F2 before the OS loads; it's often tricky timing and I have to try repeatedly). Device manager will have a red x if the port is disabled; the exclamation point (yellow triangle) indicates driver issues.
I realize this is nearly a year after you posted your questions but I hope it will help the next person searching for answers on this TV.
Dec 12, 2008 | ViewSonic N1930W 19 in. LCD TV
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Broksonic TV Logo
386 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
