Question about Chicago Pneumatic Cp7200s Mini Random Orbital Sander
HOW DOES IT WORK WITH NO CORD??? - Chicago Pneumatic Cp7200s Mini Random Orbital Sander
  • 43,501 Answers
If the product your have this listed under is correct then you need to hook up an air hose to this sander to make it work...it works on compressed air...
heatman101
Posted on Aug 21, 2010
I purchased a replacement power cord for my Bowflex TC3000. I plugged in the new cord and it is not working. Is there a known incompatibility with after market power cords for this machine?
If you have access to an ohm meter then you can verify if the plug is good or bad and you can use a volt meter to verify that the outlet is working or not. The first video shows a generic way to ohm out an extension cord. this will also work with yours. The second shows you how to check voltage at an outlet.
Jul 06, 2016 | Bowflex TC3000 Treadclimber
Pull cord will not retract
You did not say which model of vacuum you have. Cord reels are a great feature on a vacuum, when they are working properly. If your cord goes bad or the cord reel isn't working correctly it may need to be replaced.
Apr 03, 2016 | Vacuums
How to repair the pull cord on window blinds
it takes time and patience. if there is extra cord you can pull it through and try to make it work. Sometimes if you have shortened the binds ther ewill be extra cord. use this.
Sep 22, 2012 | Televison & Video
My Creature II speakers still work however the big subwoffer isnt working. I think it is probably just the cord but is there a way I can be sure
Which cord are you thinking of? If you look at the subwoofer there are 4 cords. One to the left tweeter, one to the right tweeter, one to the computer and one to the power.
  1. As both the tweeters are woring then those 2 cords are OK.
  2. As both tweeters are working then the cord to the computer is OK.
  3. As both tweeters are working then the cord to the power is OK.
  4. Therefore it is not 'just the cord.'
What I would suggest is checking that the sub has not been turned down - one of the silver posts on the sub. If that is not the case and you cannot turn the sub volume up then I suggest that you replace the system. They probably cost more to repair than to buy new.
Sep 30, 2011 | JBL CREATURE II Computer Speakers
Specific Ethernet Cord Input?
Some cords are designed for desktops and laptops and some are also ethernet phone cords for dial up users and if the short one works congrats. hope this mke you understand better.
Jan 08, 2010 | Compaq Presario 700 470024-192 Notebook
Works on batteries. does not work on ac. If you leave cord in it and turn off ac it still will not work, but if you take cord out of the unit it will then work on batteries.
If the AC cord can be removed from the back of the radio, then there is a mechanical lever inside where the AC cord plugs into the radio. That lever will cause the battery connection inside to be open (or disconnected) so that it will run off AC and not blow up the batteries. That is why it won't run on batteries when that cord is plugged in.
If it runs on batteries but not AC, find another cord to try. Most radios use about the same cord. If a second cord still doesn't make it work, it's most likely a fuse inside for the AC circuitry. they are usually mounted on a circuit board inside the radio right near where the AC cord plugs into the radio.
You should be able to take the radio apart (while it's unplugged from AC of'course) and find that fuse. If your good with a soldering iron you can replace the fuse. Replacements can be found at Radio Shack. If your reading these instructions to begin with, your probably not good with a soldering iron and you should just buy a new radio. Good luck.
Nov 26, 2009 | Durabrand CD Player with Cassette...
Electric mower not starting.
I have no idea if your problem is related to mine, but my B&D electric mower did the same. The cord worked on other equipment so wasn't a bad cord. It turned out I had to get a higher amp cord for the mower. Why it worked for a while on the other cord I don't know but I've had no further problems with it. The cord was expensive though.
May 19, 2009 | Garden
Need to lengthen handset cord for wall phone
You should be able to get an RJ-45 coupler for the cord. It may be a little awkward but should work. Try:
Radio Shack
Frys Electronics
Menards
Best Buy
Your local hardware store
Mar 21, 2009 | GE Lands Phones
Mdp 1760 - car adaptor wont work-universal quit also
I have a power cord that belonged to mine. My player quit working. You can email me at quartermiledr@yahoo.com and we can make some arrangements if you are interested.
Jan 06, 2009 | Mintek MDP-1760 Portable DVD Player
My phone does'nt work
Be sure both the line cord and the handset cord are plugged in. If they are, plug a working phone into the dead phone's modular wall outlet. If it works, assume the problem is with the dead telephone. Try plugging the dead phone into a working outlet. If it works there, its cord or modular plug may be making a poor connection with the first modular receptacle. Switch cords with the working phone and try again. If it works, replace the cord. If it doesn't work with a good cord, plugged into a working outlet, the phone is probably defective. Further isolate the problem by substituting the handset from a working phone. If it works, repair or replace the dead phone's receiver. If it doesn't, repair or replace the entire phone. Be sure the switch hook isn't stuck down or jammed.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Chicago Pneumatic Cp7200s Mini Random Orbital Sander Logo
75 people viewed this question
Top Chicago Pneumatic Tools & Hardware - Others Experts
Jim London
Jim London
elunsford
Are you a Chicago Pneumatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
