Question about Whirlpool MH1170XS Microwave Oven
Changed bulb and still not working - Whirlpool MH1170XS Microwave Oven
    Champion:
  • 245 Answers
Try turning the bulb a little tighter.
Posted on Aug 21, 2010
I have a mh1150xm microwave and changed the cooktop lightbulb. Still no light. A tech came and said that need to change whole control board. Is this true. Everything is working fine exept the light
I take it you did replace with a bulb designed to withstand heat.check the filament of bulb first these sometimes get damaged in transit.if the microwave is coming on then it won't be the fuse.if the bulb looks okay(you can check using another) finally inspect the door latch and the bulb housing and wiring to it.Sometimes door latch hole can get debris into the mechanism.cost of panel via engineer can cost quite abit..is it still in warranty? Price compare the estimation against buying new replacement.
Feb 09, 2015 | Whirlpool MH1150XMQ Microwave Oven
My surface light on our Velos does not work. I changed the bulbs but did not work.
does the unit still operate, if it does not operate replace the fuse
Jan 04, 2015 | Microwave Ovens
Changed light bulb and still don't work
Did you check the fuse ? this may need replacing also
Apr 03, 2014 | Whirlpool MH1141XM Microwave Oven
JVM1340 lights not working
Behind the top grill above the door is an access panel to change the light bulb. If the bulb is good but light still don't work, its possible the door switch is bad, but normally if the switch is bad the turn table won't work either. Most likely just a bad bulb part number you would seek is WB36X10003 this is not cheap for a bulb, you maybe able to get a replacement from a local lighting center near you. its a 40 watt, 130V bulb
Good Luck
Nov 03, 2013 | GE JVM1650 1000 Watts Microwave Oven
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
Cavity light bulb out
Most of them are a appliance bulb like a christmas tree bulb. Google how to change it..
Feb 27, 2010 | Microwave Ovens
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
