Question about GE Profile WPRE6100G Top Load Washer
Washed a load of floor rugs now washer will not drain
    Genius:
  • 1,075 Answers
Sorry but one rug is ample for any machine,but the load weight alone is far to much on the machine,i have been in a testing factory and seen the things people put in machines and it would shock you,but back to your presant problem?basicly the whole dranage system is full of heavy dirt and needs cleaned badly.Try putting two dishwasher tablets through machine and see what happens but i must say i wouldnt have high hopes,i would think lower dranage pipes are going to be cleaned.if you want my help come back to me.adrian,,,,,,,
Posted on Aug 21, 2010
How do you unclog drain on washer so it will drain again?
You need to open the water pump to see if it is clogged with any thing causing the obstruction for not draining.
Jun 09, 2014 | Maytag MAH8700A Front Load Washer
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
The front load washing machine will not drain
Look in the rear for a small door that holds the pump filter.
Drain the washer with the small tube 1st.
Nov 17, 2009 | GE WSXH208A Front Load Washer
Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
WASHED RUG IN MY NEPTUNE WASHER. rUG CAME APART. washer won't drain all the way. ND COMES UP.RUG WAS SHAG TYPE.hELP!
You will have to clean up drain system in washer. Get the rug pars out. A wet vac is a useful tool here.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis top loading Washer
try using compressed air at a low PSI (40-80) blowing through the drain hose backwards. besides that you will have to axcess inside parts to disasemble and clean the pump/hoses...
Jan 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
C1 Fault
code CL.(C1) This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. Calypo washers do have a history of break downs within the drive system.
Dec 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
