Question about Amana RFS18MPS Microwave Oven
What dont is mean error 5 model rf17 and the electronic swicht dont work 1 and 2 6 buttom swicht
  • Amana Master
  • 9,085 Answers
The service manual for models RCS10 and RFS12 is here for you to download.
The service manual for model RFS18 is here.
There is also a technical sheet inside the oven, usually located hidden on the left side near the bottom floor of the oven.
The sheet should tell you what the code means.
You can probably find exploded views and order parts by model number here.
Let me know if I can help further.
Posted on Aug 23, 2010
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
Model # JMV8208BAS
On a GE or Hotpoint, it usually means the keypad is defective. On some other brands, it means there's a sensor error.
May 16, 2016 | Microwave Ovens
For Model: URC517MP - Can you clarify Error Code C5
Hi ess0,
The Amana error code F5 means that you have a failed Electronic Range Control (ERC. The only way to resolve this problem is to have the Electronic Range Controller be replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 31, 2011 | Amana RC17 Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
2 sanyo microwave ovens dead
it sounds like u are talking about the high voltage fuse, they are not by passable unfortunately in your case. at the same time they are not expensive and easily availiable from electronics shops.
Jul 05, 2009 | Sanyo EM-S9515W Microwave Oven
Start buttom doesn't work
Okay, it does sound like your membrane keypad is worn out at the Start pad.
It may be available separately as a key sheet or already attached to a new plastic frame.
In case it comes as a key sheet and if you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
LG's Latin American Wen sites are here.
Dec 16, 2008 | LG LRM1250 Microwave Oven
Amana RFS18MPS Microwave Oven Logo
94 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
