Question about Briggs & Stratton Garden
How do I decode a Briggs and Stratton Model Number to find out horse/torque rating?
  • 40 Answers
SOURCE: need model number for Briggs & Stratton engine in
try this
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=0&LeftNav=true&model_num=147-812&serial_num=00000000
Posted on Mar 11, 2009
freetek
  • 5568 Answers
SOURCE: briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Posted on Aug 20, 2009
  • 93 Answers
SOURCE: Cylinder head bolt torque setting for a
Search Briggs on the Web, You can order Manuals there. The torque is in in. pounds. Need more info ! A just get them tight and all about the same will work, stagger the bolts in the Head when tightening ( one bolt, one side then the other until done.) Then check them all.
Posted on Sep 15, 2009
bbreton
  • 437 Answers
SOURCE: need a spark plug size for a yardpro self
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Posted on Sep 24, 2009
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
What is the head bolt torque setting
Briggs and Stratton repair manuals are available at all location ware B&S parts are sold except lowes and Home Depot. I have one in my garage the cast iron motors are different then the aluminum ones I will need the model number for the exact torque spec 60000-130000 is 140 170000-280000 is 165 Aluminum and cast Iron is 190 IN.LBS. THIS IS ALL IN IN., LBS.,
Oct 09, 2014 | Briggs & Stratton Garden
Briggs and stratton lawnmower timing
It would help to know the model number of the engine BUT the timing is controlled by the flywheel. If there is an issue it is usually because the flywheel has slipped and lost alignment with the shaft. Check the woodruff key and see if it is straight.
Jul 31, 2014 | Garden
Getting to float
take off the carb, then unscrew that big screw on the bottom. the float is in there
Jun 12, 2010 | Yard Machines 155 Torque Briggs Stratton...
I have a murray lawn mower powered by briggs and stratton, i'm trying to fing a manual on the internet but it says to put my model number, and on my engine it says that my model number is lev100 but...
The model numbers on a briggs engine are stamped into the metal cover above the spark plug and are the first 6 digits the rest are engine codes and type.
Oct 29, 2009 | Briggs Stratton 020273 Elite Series...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
847 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
