Question about Grundig Televison & Video
I have a GRUNDIG XENTIA 72 Flat Panel TV that has had problems many times over with regards to power supply. The current problem is that i had it working fine when all of a sudden sound is still OK but pic has gone totally can anyone help?
  • Grundig Master
  • 12,061 Answers
Http://www.eserviceinfo.com/index.php?what=search2&searchstring=chassis+2500+(%3DGrundig+WF82-3020A)
Above is your service and repair manual, below is the Grundig, service Information, it details may causes and fixes for you to try.
Service information at these two sites below, to assist you to troubleshoot.
http://www.scribd.com/doc/14051614/Grundig-Service-Information
http://www.scribd.com/doc/27401271/Grundig-CUC1807-1837-1838-1839-1934-1935
Power Supply repair is NOT easy, but here goes. First Without Power do as"Dry" Multimeter Ohms, check of ALL discrete components looking for "Shorts" Check, Diodes, Caps, Resistors. Coils etc.., Check all Transistors, B.C.E. with your meter set on "Diode test" look for "Bad" junctions. Then you check to see if you have power to and on the "other side" of the Bridge Rectifiers/Diodes. if not, replace that. if yes, proceed. Check for the correct Voltages around the Controller Chip. and Check the output of the Chopper Transformer, Check to see if the Waveform around the Controller IC is right. Check ALL voltages are correct & within range.. Now during this you should have found the faulty Bit(s). Replace as necessary. BE CAREFUL. I always work on ANYTHING connected to mains through an Isolation Transformer Before we can attempt to repair anything at all, there is one thing that one MUST do before anything else is done. Now that is, the making sure that the Power Supply,of the unit, no matter what it is, has the correct Voltages, coming into it, and more importantly, coming OUT of it. This is absolutely imperative, as, IF these Voltages are NOT correct then NOTHING will work, properly at all. So we must measure these voltages with a Volt Meter. All Voltage measurements are made with reference to ground. Meaning we clip, our Black, Minus, Lead onto the Earth, or Chassis, or Negative (-) "Rail" of the Power Supply. Now with the Red lead, we can now, measure these Voltages. Now sometimes, the Voltage of each Output is annotated,or written, onto the PCB, that will indicate the Voltage of that output. However most usually they are NOT, so in this case we MUST have a manual to tell us. Now this manual is called a "Service Manual" or sometimes a "Repair manual" This manual is absolutely vital so much so, that it can be near impossible to do without it. As apart from having "Troubleshooting" step through's, it also has our Voltages. When we measure these Voltages they are 100% EXACT, so IF the Voltage you measure, except for a few rare exceptions, the "Rail" that is NOT at the correct voltage is the one, that the "Fault/Cause" is "ON". Therefore we can now work outwards from the Power Supply, looking for the cause of that problem. Now if the Voltage is Lower than specified, we are invariably looking for a "Short", something has "Faulted" and is "Dragging" the Power Rail down to earth. Now if the "Rail" is "Higher" than the specified Voltage then the fault we are looking for is usually some sort of "Open Circuit" possibly a Diode, or resistor that has changed it's "Value". Now knowing this and knowing that the Power Supply is the FIRST place to start you troubleshooting and repair from. You now have a MUCH better chance of a "Fix". One thing more, DO NOT forget to get your SERVICE MANUAL. for you exact make & model. even if you pay for it, you will be glad you did.
Below is a pay for service manual link.. http://www.grundig.owner-manuals.com/XENTIA72-service-manual-GRUNDIG.html
Posted on Aug 21, 2010
Grundig elegance 72 flat screen problem
sounds like frame collapse check out repair costs as can be rather expensive
Dec 01, 2012 | Grundig Televison & Video
I have a Grundig XENTIA 82 FLAT MFW 82-430/8 TV, everytime i turn it on i get a blue screen & the child lock nb to fill in, so i have to type the nb 7038580 to watch tv... how can i cancel this koz...
If this is happening on all the channels I think you will need a total reset. If so open menu and check the settings for child lock when you manually tune. An option is to reset the channels once again after the lock is opened. Choose a new channel scan to reset the memory. However if the lock seems to be only on specified channels you can open the settings of the channel and unlock on the menu.
Oct 16, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
Powersupply went off while the current supply was disrupted for grundig Tv
Possible that the main power supply which is a switch mode power supply- SMPS - has failed.
Please check the link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 08, 2011 | Televison & Video
We are Insurance Assessors and have a client with a water damaged Grundig television. I need to know todays equivalent replacement model for a Grundig MWF83=2/490/9 Xentia 82 television as the damaged...
From what I have seen via ebay and a few other site this tv is a older model and would not be replaced by anything more than $500.00 at its current value. And thats on the high side.
May 06, 2011 | Televison & Video
When tv is off, after some time standby light flashes then switches to orange (as displayed when tv is on). Does this for hours, TV then comes on without prompting. TV is brand new but does this daily.
The problems u describing are causes by the tv power supply board.That the board,where the power a/c cord plug into it.This tv is brand new take ur warrenty repair for the power supply board or take it back where u bought it get a tv replacenent.
Jan 03, 2011 | Grundig GU22DVDPX 22 in. LCD TV
Hi i have a grundig gu22dvd the power supply keeps turning off can i buy a new poers lead and transformer
helen366, if unit continues to do same thing, I suggest you contact Grundig for warranty service to put it right again!!! You must tell them that it should not have premature failure of the internal "switch-mode-power-supply" and they should replace the unit with new or refurbished same model free of charge.
12fixlouie
Sep 24, 2010 | Grundig GU22DVDPX 22 in. LCD TV
Dear Madam/Sir - I have a Grundig Xentia 26'' LCD TV that is 4-5 yrs/o. Recently, when we turn it on, the picture comes on OK but in a few minutes the screen goes black. If I turn the power off at the wall...
Ur backlight video board,dying.Well require changing keep happening.LCD require more power and floescent lights more heat,not like cathoray tube have radiation,but more glass take heat better.
Nov 25, 2009 | Televison & Video
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
TV Volume settings
These are all settings that are put in by the factory and cannot be changed.
Nov 28, 2007 | Televison & Video
Grundig Xentia - sound but no picture
in your tv is malfunctioning high voltage, the audio is generated without the help of high voltage sistem how happens commonly in many other tv
Aug 07, 2007 | Grundig GF70-600 TV
Televison & Video Logo
685 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
