Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
My Poulan 445 Pro's Gas tank brackets worn out (melted) I went ahead and replaced washers to hold into place! now my cable for my carb. came off and now I'm looking for a diagram to show me how to install properly. Please advise
    President:
  • Poulan Master
  • 1,545 Answers
There probably is'nt a diagram to show this as there is a shortage of repair info on these units in the way of manuals etc. Most people feel they either run or they don't and treat them as a disposable item. The carb cable should have a dog-legged end on it and with the carb in place you should just be able to twist it slightly enough to drop into the butterfly valve shaft's end plate where the hole is...and make sure the raw part of the cable is around the back of any guides, so it doesn't bind up or interfere with the throttle action.
Posted on Aug 21, 2010
Testimonial: "Thank you it works!"
Fuel lines poulan bvm200vs gas blower
You need to split the entire unit to get to the fuel tank. Remove carb, remove exhaust, and remove right side of plastic enclosure. Check the cylinder to make sure it is tight, these units are notorious for the cylinder coming loose. Remove the tank and install your new fuel lines, leave them long then trim to fit once reassembled. Check to be sure the isolator mounts and starter rope ferrule are in place when reassembling
Jul 17, 2012 | Poulan Pro Gas BlowerVacuum ()
Poulan pro 550series lawn mower rust from tank plugged carb, took off tank and carb 3 or 4 times and cleaned , last time fixed rust problem primer bulb started to flake sending small pieces into carb....
You still have trash in the carburetor blocking or partially blocking. You are going to have to get some spray carb cleaner and be very thorogh about cleaning it, every hole, every passage, every thing. While you are at it if you have not recently changed the diaphram, go ahead and do that since you have it apart. The diapham is not expensive.
Sep 20, 2011 | Poulan "Poulan" Push Mower
Both lines from carb to gas tank rotted off inside of gas tank
These lines need to be replaced. If you can do it yourself go to shop and buy about 18 inches of line, also new filter. It has been my experience that you will probably end up having to go through the carb.
Oct 06, 2010 | Poulan Pro Gas BlowerVacuum ()
Pressing the primer bulb on my Poulan 450 does not inject gasoline into the carburetor; I have removed the air filter to see, because the bulb felt "softer" than it should, and no gas was injected while...
Yes, most likely the diaphragm needs replacing. Remover the air filter. Remove the bolt holding the front (sparkplug end) of the tank to the bracket. Next remove the long bolt to the left side of the carb. Carefully remove the governor linkage from the carb. Take pictures if necessary. With the car/tank assembly on the bench, remove the 5 phillips headed screws from the base of the carb. The carb should now lift off the tank. CLEAN EVERYTHING. Be careful not to lose the small spring and screen from the bottom of the carb. Replace the diaphragm set. Not that the rubber piece goes down on the tank first, then the paper piece, then the carb. Install and tighten the 5 screws. Hook up the gov linkage and reinstall the tank. If you put gas in while on the bench, you can pre-test the primer. Just be careful where you are apraying the fuel.
Aug 20, 2010 | Poulan "Poulan" Push Mower
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
I need a repair diagram for a poulan 2050 that shows just where each gasline goes. Anyone know where to go?
the bottom fuel line that goes to carb lower port also goes to the fuel tank look inside fuel tank threw gas cap hole to find the fuel filter hose is picking up the fuel and bringing the gas to the lower fuel port into carb (the upper from carb goes to prime or return to tank)
May 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
169 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
