Question about Philips Brilliance 109S Monitor
I have a monitor that was given to me.
I have a viewsonic monitor not sure of the model . i would like to know howto get the OSD lock off to adjust the color settings. Can someone help me with this please?????
  • Anonymous Jun 08, 2008
    hey there i have the problem when i pres the "ok" its control meny is locked i try the first solution and wont work can u help me plsss
    i priciated your help
    Guru:
  • 1,342 Answers
OSD Lock Settings
You have the option of using the OSD Lock feature to prevent current image
adjustments from being changed.
• OSD Lock: Press and hold [1] and [J]
for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and [J]
again for 10 seconds.
Posted on May 03, 2008
Osd display is locked on q22wb monitor
Please contact ViewSonic Customer Care to get support for this. There is a special set of macro keys to press to lock and unlock the OSD. But you need to call Customer Care to get this resolved.
Jun 29, 2014 | ViewSonic Q22WB 22" LCD Monitor
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
My monitor osd lock . how i can open. viewsonic e55
Most monitors that have the OSD menu locked can be unlocked by holding down the OSD button for 20-30 seconds. Try it.
Hope this helps! :D
Sep 08, 2010 | ViewSonic E55 15" CRT Monitor
OSD Lock
OSD lock is a feature which locks the OSD. It can be enabled or disabled by pressing the menu button for 10 sec. It is the lock which locks the On Screen Menu for changing the menu settings.
To unlock press and hold the menu button for 10 sec.
Thank you Sir, Have a nice day.
Sep 23, 2009 | ViewSonic E70f 17" CRT Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
Viewsonic E72f+ OSD Locked
press and hold the 2 button... the button which has named 2 on it... for some seconds... maybe 10...
Jan 03, 2009 | ViewSonic E70f 17" CRT Monitor
Osd lock
turn the monitor off then hold the menu button and turn it back on at the same time
Jul 28, 2008 | Computers & Internet
OSD lock - I think
This is for Viewsonic LCD, but it's probly pretty similar for you...
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
raj, rajkumar.ranju@gmail.com
Jul 22, 2008 | ViewSonic E70f 17" CRT Monitor
Viewsonic g71f+
the feature will be called Auto Adjust on your osd menu, I'm not quite sure where exactly it will be but by clicking on this within the menu will fit it perfectly to your screen. It possibly will even be it's own button on the screen. Since I am not totally familiar with this exact model, I can't be more specific but if you are having trouble, please let me know the options and I can tell you where to look since all monitors are basically the same.
May 17, 2008 | ViewSonic G71F+B-2 17 in.CRT Conventional...
Philips Brilliance 109S Monitor Logo
546 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
