Question about Franke WD751B GPS Receiver
I haved Franke Triflow filtration system, HT-200. Water leaks from both sides of 1/4" T-Connector Push Fit. How do I fix it?
I have the counter top water filtration system. It is leaking from the back underneath. Can I fix this?
If it is leaking at the supply connection, then it can be tightened. If it is leaking from the body, then it must be replaced.
May 06, 2017 | Water Water Heaters
I also have a Franke 200 series faucet and it's leaking where pullout spray attaches to supply tube after replacing washer....is it possible for sprayer hose to leak...its silver not just a nylon hose
Although I am unfamiliar with the name "Franke", I am more than familiar with this problem.
I have had it too many times to count.
I have discovered it takes an assortment of black rubber/plastic washers to fix this.
I even have them in my tool box for this very problem.
Not enough washers will cause a leak, too many and the hose will not ***** on.
I have had to experiment with different washers to get the fix.
God bless your efforts.
Apr 04, 2016 | Franke Plumbing
Franke Little Butler not heating
If not tank filling ur heater wont start mostly ur soleniod valve for incomimg water spoiled. Also ur heater might be open or heater'$ thermal fuses open, if have.
Sep 22, 2014 | Franke Water Dispenser Tank Little Butler...
Water filtration system leaking at spout
sounds like you water inlet valve is failing, this is a electric water switch... i suggest you turn off the water to the frig...
Dec 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Fixing a franke sink
Turn sink upside down on paper/cardboard & trace around outside. . Measure from outer edge of unit to just beyond inner edge [where the clips fit] transfer this to cutout and mark/cut on this inner line. This is not your template to cut out the worktop.
Push the clips over the inner ridge on the underside until they click into place.on small cutouts make sure the worktop grips face outwards.
place into worktop cutout - most likely there will be some more worktop to trim to fit. When fitting easily, fit the seal on the underside where the sink fits into the worktop & screw up the clips until they bite into the underside of the worktop.
Not got the seal? use silicone [clear]
Aug 31, 2009 | Home
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric GE SmartWater Household...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Freon leak
If your going to attempt this yourself then you need a few things.
Go to your local car parts shop. You will need a Toyota Corrola Manual in order to find the connector on the low pressure side of your AC compressor.
You will need to find this connector first to determine if the connector is a screw fit or a quick release push fit. You also need to work out what refrigerant to add to your car - R22 or R134a. R134a is more environmentally safe ( the numbers are from memory so may be slightly different but buy the manual and check that first for the type of refrigerant used in your model).
You also need to look for a Recharge can with Stop leak and Leak detector in it - they will have it at the auto shop should be under $20 (you may wish to buy two cans just in case as often one isn't enough) - and once you know the type of fitting you need to use you need to by the recharge connector that will fit on the low pressure side and attach to the top of the recharge can.
Typically the leak detector can be a red dye that can be seen by the eye or a yellow dye that glows under untraviolet light - so if you don't have an ultra violet light source its going to be difficult to see the leak with the yellow stuff . The other problem you may have is if the leak is really bad the system may need to be fixed (stop the leak) and the evacualted for the AC unit to really become effective.
Anyway the practice is to find the recharge connection on the low pressure line. Take the cap off.
Connect the recharge hose you bought to the recharge can. This end of the hose has a tap and spike arrangement that is going to puncture the top of the can but you make sure the tap is fully wound out (away from the can) when you fit it initially. Later in the process you are going to wind the pin in to puncture the can once its all set up. So with the can connnected to that end of the hose you have to fit the other end of the hose to the low pressure side of the AC line on the Corrola. Do that as quickly as possible - if its a push fit with locking ring the action of you pushing the connector on does two things opens the AC system and seals the tube connector onto the Low pressure side. Its inportant to do this as fast as possible to prevent any refidgerant that may be in the system from leaking out and to prevent contaminants getting into the system.
Start the car.
Put the AC on full
Go back to the engine and wind the spike into the can fully to puncture the can it and then wind the spike back out again to allow the refrigerant to enter the AC system.
The can should get pretty cold even to the point of icing a little.
Go back in the car and with the AC system on full and the blower turned on to say the 2nd fan position check for cooler air starting to come through the vents in the car.
You should be able to go back round to the engine after say 5 mins and check that the recharge can is now empty.
Screw the spike back into the can - turn the AC and the engine off and disconnect the low pressure side connector on the hose. If its a push fit it has a brash ring you have to pull up to release the tube and then pull the tube off the system.
You can repeat the process with the 2nd can if needed now.
Screw the protective cap back on once you have completed all recharging.
Now two things to check - where are any signs of red dye coming out of the AC system and 2nd does the AC actually work.
If the AC still doesn't work it may just be that you have such a drastic leak that the system needs to be fixed - e.i. a condenser unit replaced or something and now you are into $100s to fix it.
Good luck.
Aug 08, 2008 | 2005 Toyota Corolla
GPS Logo
381 people viewed this question
Top Franke GPS Experts
Are you a Franke GPS Expert? Answer questions, earn points and help others
