Question about HP PSC 750 All-In-One InkJet Printer
Carraige return pull came off
The carriage return pull came off the cartridge part of the printer. Is there a way to reattach it?
  • mbsfutbol Jun 13, 2008
    When replacing the black ink the top part that comes down to hold it - the black piece and the spring came off. it does not look broken, but i do not want to break it when replacing it
I'm assuming you mean the strip of translucent plastic on which the carriage runs. I was able to reattach mine - it requires small hands and a flashlight, as well as some patience!
The punched-out holes at each end of the strip have to be correctly aligned to fit into the metal prongs (I found the left side to be most difficult). It took me four or so tries and about twenty minutes.
Posted on May 05, 2008
Epsom Stylus TX110. Cannot get cartridges out.
Press and hold the ink button for three seconds (similar to head cleaning). If the machiune thinks a cartridge is empty, the carriage will move all the way left and then return to the point where the offending catridge can be removed. If that doesnt work, start the machine doing anything to get the carriage away from the cleaning station and pull the power plug out. You can then manually move the carriage to where-ever you want.
Jun 28, 2014 | Epson Stylus Office Equipment & Supplies
Disconnected white cable
if it is a flat cable some of them had a little clip that would slide back allowing you to reattach the cable some do not
Jan 29, 2014 | Kodak ESP Office 2150 Wireless All-In-One...
I need to change a faulty cartridge before it is empty
ok here is the way to get it. but you have to be quick.
Be close to the power cord at rear or the MAINS power switch
. Turn the printer on, and as it initialises it will unlock the carriage of cassettes. This usually causes it to travel out from its home a small way before it returns to rumble around to clean itself. The moment it moves off the base, pull out the power cord or turn off the mains. The carriage can now be manually pushed to the location that allows you to remove the cartridges. Replace the faulty one and manually return the carriage to its home. Replace the power cord or reinstate the power. Allow the printer to reinitialise and go through its usual paces.
Please rate my help++++Thanks for using FIXYA
Jul 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How to remove the cartridge from hp photo smart 7960
Hello the manual way to release cartridge is
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Look for the gray-colored carriage on the right side of the printer.
  4. Find the horizontal (bottom) edge of the carriage and follow it towards the back (or in) until it makes a 90-degree turn. Follow it down to the ¼ inch-high, black-colored capping station.
  5. Using a screwdriver or similar tool, push the capping station toward the back of the printer.
    NOTE: Do not pull on the ribbon cable when moving the carriage.
  6. Making sure to not push up on the carriage, move the carriage to the middle of the printer. If the carriage is still locked in place, push the capping station farther into the printer and try moving the carriage again.
  7. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges and store them according to specifications.
  8. Close the top cover.
Sep 03, 2009 | HP PhotoSmart 7960 InkJet Printer
Can't change color cartridge
Unplug the printer from power and manually move the head to position. Remove the tape and plug the power in again. With the access door closed, the head/cartridge assembly should return to 'park'.
Aug 16, 2009 | Epson Stylus C40UX InkJet Printer
My brand new printer is displaying printer error code 5100 and will not print or recognise the ink not sure if this means the ink cartridges are faulty.
That error translates as a "Carriage error"... which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Check you've installed the cartridges correctly and that the grey lever that holds down the printhead, etc.. has been put in the down and locked position.
You may find that you've installed the printhead incorrectly so worth pulling out the cartridges, removing the printhead and then reseating it so the lever goes down to a horizontal position. Then reinsert the cartridges.
If that doesn't solve it the best course of action is to return it and demand a replacement.
Feb 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
We have a hp deskjet f4140 printer that had a paper jam. My wife pulled the paper out of it, and it is acting crazy now. It told me that it was low on black ink, so I replaced the cartridge with a new hp...
Does the carriage move and home out when you power up the printer? If not, look inside the cavity where the carriage assembly is and look for a skinny little piece of plastic, it should be anchored on either side of the printer frame with a small spring on one side. it should go thru the carridge assy. This is the encoder strip. The carriage uses it for reference when it moves. If this strip has been knocked out of position the machine almost immediately signals an error, (attention light flashes). If this is the case, then the challenge is to A-find the spring and B-reattach the encoder strip. Good luck.
Larry
Dec 01, 2008 | HP Office Equipment & Supplies
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
