Question about 1995-1997 Yukon Ignition Starter Alarm Switch
CAN A IGNITION SWITCH CAUSE TRANSMISSION PROBLEMS
    New Friend:
  • 103 Answers
Yes it can. There is a thick WHITE colored wire, that needs to power up as a true ignition wire or it will not activate the electrical portion of your transmission. This is a common known problem especially with dealing with remote starters in these vehicles.
Posted on Aug 21, 2010
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have a chevy expr er van .can a bad ignition cause problems with transmission
Posted on Dec 15, 2017
DOES A FAULTY IGNITION SWITCH HAVE ANYTHING TO DO WITH TRANSMISSION PROBLEMS
No, not unless you have performance transmission mode that can be tur.ed on electronically. A faukty ignition switch could intercere w that vut in your vehi le, it would not have that, so no.
Feb 27, 2014 | 1998 GMC Jimmy
Tip
Ford OBD-II Trouble Codes
P1000 OBD-II Monitor Testing Incomplete<br />P1001 KOER Test Cannot Be Completed<br />P1039 Vehicle Speed Signal Missing or Improper<br />P1051 Brake Switch Signal Missing or Improper<br />P1100 Mass Air Flow Sensor Intermittent<br />P1101 Mass Air Flow Sensor out of Self-Test Range<br />P1112 Intake Air Temperature Sensor Intermittent<br />P1116 Engine Coolant Temperature Sensor is out of Self-Test Range<br />P1117 Engine Coolant Temperature Sensor Intermittent<br />P1120 Throttle Position Sensor out of range<br />P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor<br />P1124 Throttle Position Sensor out of Self-Test Range<br />P1125 Throttle Position Sensor Intermittent<br />P1127 Heated Oxygen Sensor Heater not on During KOER Test<br />P1128 Heated Oxygen Sensor Signals reversed<br />P1129 Heated Oxygen Sensor Signals reversed<br />P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1<br />P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1<br />P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1<br />P1135 Ignition Switch Signal Missing or Improper<br />P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1<br />P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1<br />P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2<br />P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2<br />P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2<br />P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2<br />P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2<br />P1220 Series Throttle Control fault<br />P1224 Throttle Position Sensor B out of Self-Test Range<br />P1230 Open Power to Fuel Pump circuit<br />P1231 High Speed Fuel Pump Relay activated<br />P1232 Low Speed Fuel Pump Primary circuit failure<br />P1233 Fuel Pump Driver Module off-line<br />P1234 Fuel Pump Driver Module off-line<br />P1235 Fuel Pump Control out of range<br />P1236 Fuel Pump Control out of range<br />P1237 Fuel Pump Secondary circuit fault<br />P1238 Fuel Pump Secondary circuit fault<br />P1250 Lack of Power to FPRC Solenoid<br />P1260 Theft Detected - Engine Disabled<br />P1270 Engine RPM or Vehicle Speed Limiter Reached<br />P1288 Cylinder Head Temperature Sensor out of Self-Test Range<br />P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range<br />P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range<br />P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition<br />P1309 Misfire Detection Monitor not enabled<br />P1351 Ignition Diagnostic Monitor circuit Input fault<br />P1352 Ignition Coil A - Primary circuit fault<br />P1353 Ignition Coil B - Primary circuit fault<br />P1354 Ignition Coil C - Primary circuit fault<br />P1355 Ignition Coil D - Primary circuit fault<br />P1356 Loss of Ignition Diagnostic Module Input to PCM<br />P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range<br />P1359 Spark Output circuit fault<br />P1364 Ignition Coil Primary circuit fault<br />P1380 VCT Solenoid Valve circuit Short or Open<br />P1381 Cam Timing Advance is excessive<br />P1383 Cam Timing Advance is excessive<br />P1390 Octane Adjust out of Self-Test Range<br />P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage<br />P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage<br />P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed<br />P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose<br />P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose<br />P1407 EGR No Flow Detected<br />P1408 EGR Flow out of Self-Test Range<br />P1409? EGR Vacuum Regulator circuit malfunction<br />P1409? Electronic Vacuum Regulator Control circuit fault<br />P1410 EGR Barometric Pressure Sensor VREF Voltage<br />P1411 Secondary Air is not being diverted<br />P1413 Secondary Air Injection System Monitor circuit Low Voltage<br />P1414 Secondary Air Injection System Monitor circuit High Voltage<br />P1442 Secondary Air Injection System Monitor circuit High Voltage<br />P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault<br />P1444 Purge Flow Sensor circuit Input Low<br />P1445 Purge Flow Sensor circuit Input High<br />P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank<br />P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction<br />P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank<br />P1455 Substantial Leak or Blockage in Evaporative Emission Control System<br />P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction<br />P1461 Air Conditioning Pressure Sensor circuit Low Input<br />P1462 Air Conditioning Pressure Sensor circuit high Input<br />P1463 Air Conditioning Pressure Sensor Insufficient Pressure change<br />P1464 ACCS to PCM High During Self-Test<br />P1469 Low Air Conditioning Cycling Period<br />P1473 Fan Secondary High with Fans Off<br />P1474 Low Fan Control Primary circuit<br />P1479 High Fan Control Primary circuit<br />P1480 Fan Secondary Low with Low Fans On<br />P1481 Fan Secondary Low with High Fans On<br />P1483 Power to Cooling Fan Exceeded Normal Draw<br />P1484 Variable Load Control Module Pin 1 Open<br />P1500 Vehicle Speed Sensor Intermittent<br />P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure<br />P1502 Invalid or Missing Vehicle Speed Message or Brake Data<br />P1504 Intake Air Control circuit malfunction<br />P1505 Idle Air Control System at Adaptive Clip<br />P1506 Idle Air Control Over Speed Error<br />P1507 Idle Air Control Under Speed Error<br />P1512 Intake Manifold Runner Control Stuck Closed<br />P1513 Intake Manifold Runner Control Stuck Closed<br />P1516 Intake Manifold Runner Control Input Error<br />P1517 Intake Manifold Runner Control Input Error<br />P1518 Intake Manifold Runner Control fault - Stuck Open<br />P1519? Intake Manifold Runner Control Stuck Open<br />P1520? Intake Manifold Runner Control circuit fault<br />P1519? Intake Manifold Runner Control fault - Stuck Closed<br />P1520? Intake Manifold Runner Control fault<br />P1530 Open or Short to A/C Compressor Clutch circuit<br />P1537 Intake Manifold Runner Control Stuck Open<br />P1538 Intake Manifold Runner Control Stuck Open<br />P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw<br />P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection<br />P1550 Power Steering Pressure Sensor out of Self-Test Range<br />P1605 PCM Keep Alive Memory Test Error<br />P1625 Voltage to Vehicle Load Control Module Fan circuit not detected<br />P1626 Voltage to Vehicle Load Control Module circuit not detected<br />P1650 Power Steering Pressure Switch out of Self-Test Range<br />P1651 Power Steering Pressure Switch Input fault<br />P1700 Transmission system problems<br />P1701 Reverse Engagement Error<br />P1702 Transmission system problems<br />P1703 Brake On/Off Switch out of Self-Test Range<br />P1704 Transmission system problems<br />P1705 Manual Lever Position Sensor out of Self-Test Range<br />P1709 Park or Neutral Position Switch out of Self-Test Range<br />P1710 Transmission system problems<br />P1711 Transmission Fluid Temperature Sensor out of Self-Test Range<br />P1713<br />thru<br />P172 Transmission system problems<br />P1729 4x4 Low Switch Error<br />P1740 Transmission system problems<br />P1741 Torque Converter Clutch Control Error<br />P1742 Torque Converter Clutch Solenoid Faulty<br />P1743 Torque Converter Clutch Solenoid Faulty<br />P1744 Torque Converter Clutch System Stuck in Off Position<br />P1745 Transmission system problems<br />P1746 Electronic Pressure Control Solenoid - Open circuit<br />P1747 Electronic Pressure Control Solenoid - Short circuit<br />P1749 Electronic Pressure Control Solenoid Failed Low<br />P1751 Shift Solenoid No. 1 Performance<br />P1754 Coast Clutch Solenoid circuit malfunction<br />P1756 Shift Solenoid No. 2 Performance<br />P1760 Transmission system problems<br />P1761 Shift Solenoid No. 3 Performance<br />P1762 Transmission system problems<br />P1767 Transmission system problems<br />P1780 Transmission Control Switch circuit is out of Self-Test Range<br />P1781 4x4 Low Switch is out of Self-Test Range<br />P1783 Transmission Over-Temperature Condition<br />P1784 Transmission system problems<br />P1785 Transmission system problems<br />P1786 Transmission system problems<br />P1787 Transmission system problems<br />P1788 Transmission system problems<br />P1789 Transmission system problems<br />P1900 Transmission system problems
on May 23, 2011 | Ford F Cars & Trucks
I have a 1999 chev 1500 4x4 will not shift any higher than 2nd gear. when it tries to shift it's like it goes int nutreal and you have to manuely down shift to make go back into gear
The problem could be related to service bulletin. It refers to check for loss of power to the transmission shift solenoids. This defaults the transmission to second gear. The most likely cause of this condition may be a loss of voltage to the transmission solenoid power supply circuit. This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system. If the vehicle is equipped with an aftermarket electronic device, and the DTCs are being set when the device is being used, verify that the appropriate fuse is being supplied battery voltage during operation. If voltage is not present at this fuse, these DTCs will be set due to lack of voltage at the solenoids. This condition is most likely to occur with an incorrectly installed remote starting system. With the ignition switch in the run position, test for battery voltage at the circuit fuse in the transmission solenoid power supply circuit. If battery voltage is present at the fuse, inspect the ignition voltage circuit between the fuse and the transmission for possible opens, else, test for continuity between the fuse and the ignition switch. If NO continuity is between the fuse and the ignition switch, repair the open in that circuit. If you have continuity between the fuse and the ignition switch, the most likely cause is the ignition switch. Replace the ignition switch. If you do need to replace any of your car parts this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/
Sep 11, 2013 | Cars & Trucks
Where is the overdrive switch on the transmission of a 1999 Ford Contour
This is called the "Transmission Range Sensor", or sometimes the "Neutral Safety Switch." It is located on top of the transmission, between the engine and the battery. If it is defective, it can cause a number of problems, including erratic down-shifting out of, and then back in to, overdrive.
If you decide to change this switch, follow this procedure. Set the parking brake and block the wheels to prevent the car from moving. Turn the ignition switch to "On" (don't start the engine), then put the shifter in neutral. Turn the ignition off, then disconnect and remove the battery. Remove the rubber boot between the air intake box and the throttle body. Disconnect the wiring harness from the switch, remove the two 8mm bolts that hold it in, then pull the switch straight up and out. Take note of how it engages the shaft inside the transmission.
Put the new switch in, leaving the bolts loose. (Make sure the two lines on the switch line up with each other. This sets it to the neutral position.) Tighten the bolts, and put everything else back together. Hopefully, this will fix your problem.
Jul 27, 2013 | 1999 Ford Contour
Transmission is not shifting but trans is good, computer is good too
Wow! That sounds like a really expensive way to diagnose the problem! YES, a bad ignition switch can can cause your transmission to not shift correctly. If the problem had been properly diagnosed, you would have known this LONG before replacing the computer and the transmission if this was the cause. You say you "checked [your] wires" and that "all [are] good", but apparently, this is not the case. If the wires had been PROPERLY checked, you would know if you have the correct voltage at the transmission solenoids from the ignition switch and it would be unnecessary for you to ask this question.
May 13, 2012 | 1997 GMC Jimmy
I have had a lot of problems with the Vectra 2005, engine 3.2. The codes that it shows are P0743, toque converter clutch. Also P1700 and U2103. In may we repaired the transmission, it works for 2...
find a mechanic isnt just "taking" your money. ok when u had the trans replaced did they put a new torque converter in? if they didnt install a new converter this very well may the cause of your problem
Aug 29, 2011 | Chevrolet Colorado Cars & Trucks
1994 Chevrolet G30 transmission problem
Its most likely the brake light switch, also connected to the steering column. It controls the Torque Converter Clutch, and when it is out of adjustment, it will not engage upper gears properly...The computer gets confussed and tries to protect the transmission.
May 11, 2010 | 1994 Chevrolet Sportvan G30
Transmission question
if the park neutral safety switch doesnt work corectly. the winning noise could be a pully or idle control on the car if it has one
Mar 04, 2010 | 2005 Toyota Corolla
1995-1997  Yukon Ignition Starter Alarm Switch Logo
1,315 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
