Question about Dell P703w Printer
I am trying to print a birth announcement that is 5 1/2 by 7 in. When I try to print it refuses because it says I have the wrong size paper in the printer. About ready to throw this printer out the door
I am trying to use the 4-6 photo tray to print from my camera.Saays the size does not fit .Also this unit will print onto paper no problemo can you help me?Regards
Posted on Oct 05, 2010
HpC309g printer keeps gaming -reason Wrong size paper but it is not
The document you are trying to print is set to a different paper size than the printer has. It is looking for paper of the correct size to be installed so it can print the document.
Aug 28, 2014 | HP Photosmart C309g Premium All-in-one...
Mx 2830 - fails to print - asks to add extra plain paper
Check the paper type and paper size in the Printer Properties. Set them according the actual paper used in the printer. Check the paper size in your document you want to print. Correct, if differs from the printer's paper size.
Jan 09, 2014 | Sharp Office Equipment & Supplies
Changing paper size on ALC2600 from LT to A4
clear the print queue
then when you go to print click on printer settings and select a4 size click apply or make default
Mar 23, 2017 | Epson Office Equipment & Supplies
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
My brother HL2040 printer shows out of paper when it has paper.
try turning it off, diconnect from computer.. Leaving it disconnected,turn it on, when green light indicates it is ready, tap the green go button 5 times real quick.
this should print a self test, if that works as I suspect it may, it is because the document that the computer is trying to print is not the same paper size as set on printer or trying to print to wrong trat ie bypass, ensure paper type is set to plain too.
If a test page tried to print but then came up out of paper, check there is nothing stuck in paper path (rear door?) and if game, give rubber feed roller a clean
Chances are and I;ll lay me bet 10-1 that paper size of document is different than tray setting and placing a sheet of paper in bypass(slot at front) is what your machine is trying to say to you. see how ya go..cheers
Nov 03, 2009 | Brother HL-2040 Laser Printer
I am making a baby shower announcement. The paper is not a standard size. It is recommended that I manually feed it. I don't know how.
first go to control panel and select printers and faxes.... in there right clik ur printer and choose printer preferences..... choose the printing shortcuts.... in the left side u ll have a list of available types of print... select ur required type... on the right u have paper source .... select automatic.... and then next to the printing shortcuts tab... go to features tab... there in the resizing options ..... choose custom and put in the size of the paper u want to print in.....
Make sure that the paper exit tray is extended out. This will give your print job a place to rest when finished.
Feed the paper manually through the paper support. This should be done at the speed the printer allows. Do not try to rush the paper through.
Watch the paper come out through the paper exit tray. Make sure it is not crooked or creased.
thank you
have a nice day
Apr 12, 2009 | HP PhotoSmart 7260 InkJet Printer
I am making some birth annocument cards overall card sixe 17.7cm x 11.4. when folded will be8.8am x 11.4. Ihave insters to use inside with birth info these are 16.6x10.9. I have tried to set up document...
I am Satya.
Hope this will solve the problem.
1.From the File menu in MSWord document click on Page setup.
2.In the page setup window click on Margins tab.
3.In the Orientation applet of Margins Page select Landscape.
4.Next click on Paper tab.
5.From the Paper size drop down list in Paper page select Letter.
6.Finally click on OK button at the bottom of the Page setup window.
7.Now type in the poem on the left hand side and the birth news on the right hand side by indenting them using the Tab key from your keyboard.
Hope this helps.
Thank you.
Aug 14, 2008 | Computers & Internet
Printing an 5.5 " by 8.5 " announcement on my inkjet printer
Dear Sppamelot You did not write the software name, in which you are working. Place / open your document in word, coreldraw or pagemaker, photoshop or adobe reader. Put this document exectly in page shown on your screen, where you want to print. Size dosn't matter. it will print exect that place, where you have put it.
Apr 16, 2007 | HP PSC 1315 All-In-One InkJet Printer
Will not print 4 x 6 prints
try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Sep 25, 2006 | Canon S520 InkJet Photo Printer
Dell P703w Printer Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
