Question about Mitsubishi WD-60735 Projection Television
Can i just replace the lamp on my mitsubitshi wd-60735 or do i have to replace it with the cartridge also
  • 10,594 Answers
Original lamp comes in cartridge, longer lasting and easy to replace
Bulb that replaced in old lamp cartridge is low cast thing and does not work longer.
Choice is yours.
Posted on Aug 20, 2010
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: -- "wd-60735 lamp was replaced have sound but no
check your Lamp Fan if it stops running when Lamp trys to light ,then it is defective ,but if it is ok Ballast Board could be the problem, it is what Powers the Lamp ON.
Posted on Aug 23, 2011
I see no picture
Televisions covered: Mitsubishi DLP High-Definition Televisions:
C Series: WD-60C8, WD-65C8, WD-73C8
735 Series: WD-60735, WD-65735, WD-73735
736 Series: WD-65736, WD-73736
835 Series: WD-65835, WD-73835
Here's an online version of your televison's (94 page) "Owner's Guide":
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf
It sounds like the lamp in your "Mitsubishi Lamp-Cartridge" blew.
If your TV remains under warranty, you'll want to call Mitsubishi at 1-800-553-7278, and you'll need to have (a) Mitsubishi Model number, (b) serial number, (c) TV purchase date, and you'll have to ship the old lamp module back to Mitsubishi so that:
"All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect verification."
Return old Lamp-Cartridge to:
Mitsubishi Digital Electronics America
1001 Cherry Drive, Suite 2
Braselton, Georgia 30517
If you have trouble finding your TV's information, you need better "Warranty Management". Warranty Management can be done with software, or on paper. You may even choose to toss all your Owner's Manuals into a box, with the receipts. In case anything malfunctions/needs to be reprogrammed/reset then the manual & spare parts/cables (in a large Zip-Loc(R) baggie or two) can be quickly located and consulted.
If you television happens to be out of warranty, a nice (expensive) new lamp module can be ordered from Mitsubishi by calling 1-800-553-7278, or by ordering online at http://www.mitsuparts.com.
Refer to pages 75-76 of your Owner's Guide for complete Lamp-Cartridge module replacement instructions (with nice illustrations).
Your TV's Lamp-Cartridge part number is: Mitsubishi 915B403001
Here's an online source for the Mitsubishi 915B403001 Lamp-Cartridge:
http://www.dlplamps.com/products/mitsubishi-dlp-lamp/mitsubishi-915b403001.html?gclid=CLzb6ciaiq0CFQdN4AodZkMonA
Note that with the dlplamps.com offerings, you can purchase the lamp only for $109, or the entire lamp-cartridge module for $129. So you can save yourself $20 if you're handy. Remember to keep all fingerprints off the lamp glass element - this small amount of oil will weaken the glass, and cause premature failure of the lamp. In the event that you get a fingerprint on the lamp glass, erase it thoroughly with rubbing alcohol. Alternatively, one may prevent fingerprints with latex gloves (make sure you haven't an allergy to latex, though).
If the reason that the lamp blew turns out to have been a clogged Lamp-Cartridge Filter (once you have the Lamp-Cartridge out of the TV and in your hand, you'll be able to easily see the mesh filter), then place a regular PM (Preventative Maintenance) of this filter on your calendar.
Dec 17, 2011 | Mitsubishi WD-60735 Projection Television
How do i replace the lamp on the wd-60735
  • Sir try to follow this, turn off your Mitsubishi DLP television set. Unplug the TV from the wall outlet.Find the lamp compartment which is located on the back of the television in its lower right corner. Use a Phillips screwdriver to loosen the screw located on the left side of the cover. Remove the cover and save it and the screw for replacement after you have changed the lamp assembly.Loosen the two metallic Phillips screws on the lamp cartridge. They will not pull all of the way out, but you can loosen them enough that they are simply hanging there. Good day and best regards hope this helps.
  • Sep 21, 2011 | Mitsubishi WD-60735 Projection Television
    Aug 23, 2011 | Mitsubishi WD-60735 Projection Television
    Try to check the lamp ballast may be damage or needs some replacement, good day and best regards.
    Aug 23, 2011 | Mitsubishi Televison & Video
    I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
    Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
    May 18, 2011 | Mitsubishi WD-60735 Projection Television
    When I replace the lamp in my wd 60735 is there a timer I have to reset ?????
    As soon as the set is powered up after replaceing the lamp. The set should bring up the screen that asks if you have replaced the lamp. Just select yes and that resets the lamp life.
    Nov 05, 2010 | Mitsubishi WD-60735 Projection Television
    How do you change the lamp in a Mitsubishi model WD 60735 projection TV
    Try website like Youtube.com,search type in ur tv model,make and projection lamp replacement.U will have somebody,have a tutoring video doing it.
    Oct 04, 2010 | Mitsubishi WD-60735 Projection Television
    I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
    Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
    Aug 14, 2010 | Mitsubishi WD-60735 Projection Television
    I don't have an owner's manual for my wd 60735, but I need to change the bulb. whatt are the steps I should follow?
    Removing the Old Lamp Cartridge
    Turn off TV power a 1. nd allow the lamp to cool for at
    least one hour before proceeding.
    2. After the lamp has cooled, remove the cover of the
    lamp compartment, located on the back of the TV.
    Refer to figures 1 and 2. Use a #2 (large) Phillips
    screwdriver to loosen the screw securing the cover.
    Keep the screw and cover for re-installation
    3. With a large Phillips screwdriver, loosen the two
    shiny screws securing the lamp cartridge until they
    disengage from the mating threads. These are
    captive screws and cannot be separated from the
    lamp cartridge.
    4. Fully open the bag supplied with the replacement
    lamp and set the opened bag aside.
    5. Gently grasp the handle of the lamp cartridge and
    pull the old cartridge straight out. See figure 3.
    CAUTION: Do not tilt or rotate the cartridge, as
    small glass fragments may fall out.
    6. Without tilting or putting down the lamp cartridge,
    insert it into the opened bag. Close the bag while
    being careful not to let any glass particles fall out.
    Installing the New Lamp Cartridge
    1.
    Do not touch the glass parts of the new lamp cartridge.
    Insert the new cartridge into the TV in the
    same orientation as the old cartridge. Push on the
    cartridge housing until it is fully seated.
    2. With either your fingers or the screwdriver, gently
    tighten the two shiny screws. If using a screwdriver,
    AVOID OVERTIGHTENING!
    3. Replace the plastic cover and retaining screws.
    4. WASH YOUR HANDS THOROUGHLY, AS THIS
    LAMP CONTAINS MERCURY.
    Nov 11, 2009 | Mitsubishi WD-60735 Projection Television
    Mitsubishi WD-60735 Projection Television Logo
    180 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
